They say I dont have a trans temp sensor
Old Oct 7, 2011 | 01:30 PM
cutthroatxxx's Avatar
cutthroatxxx
Default They say I dont have a trans temp sensor
Dont know if I should of put this in my other thread or not bit if so sorry,well I keep getting codes that theres to much electric@trans temp sensor&so I decided Ill just change it well I called oriley,autozone,the dealer&all said my truck which is in my sig,had no trans temp sensor is there a part number or diffrent name I can have them loom for?
Old Oct 7, 2011 | 01:42 PM
Trans temp sensor on yours is located in the output cooler line, right by the trans. There will be an electrical connector going to it.
Old Oct 7, 2011 | 01:48 PM
cutthroatxxx
So it not in the pan?
Old Oct 7, 2011 | 01:52 PM
Nope, go out, crawl under there, and have a look.
Old Oct 7, 2011 | 02:55 PM
kadetklapp's Avatar
kadetklapp
While we are on the subject, at what temp does the light kick on?
Old Oct 7, 2011 | 03:38 PM
Above 250 or so..... don't know the exact number.... HOT.
Old Oct 7, 2011 | 05:37 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Here's the TSB, and some one needs to download the manual from the FAQ/DIY section, or get a Haynes atleast.
http://dodgeram.info/tsb/1995/08-06-95.htm
Old Oct 7, 2011 | 09:17 PM
cutthroatxxx
Just came from buying the haynes&heyyou how do I eliminate that check valve&the plug to trans temp sensor was lose hope that waa the problem!
Old Oct 7, 2011 | 09:28 PM
merc225hp's Avatar
merc225hp
How to remove the check valve link.
https://dodgeforum.com/forum/2nd-gen...ve-delete.html
Old Oct 7, 2011 | 09:55 PM
cutthroatxxx
Thank you!
