1996 Dodge Ram 1500
Old 10-20-2011, 01:52 PM
96Dodger's Avatar
96Dodger
96Dodger is offline
Default 1996 Dodge Ram 1500
I have a 96 ram that I just bought they just had the tranny rebuilt but has had shifting problems since I got it well I topped the fluid off and have drove it for 4000 miles well on my way home from work the gas pedal was feeling a little weird like it had no power i got to the stop light and went to take off and no response out of the transmission couldn't go in any gear i moved the shifter to any suggestions what it might be
Old 10-20-2011, 04:57 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,275 Likes on 3,022 Posts
If fluid is good, either the governor pressure sensor, or solenoid failed, or, it's time for another rebuild.
Old 10-20-2011, 06:10 PM
96Dodger's Avatar
96Dodger
96Dodger is offline
Well the fluid was empty but I had just put some in on Sunday and have been watching and there wasn't any sign of a leak anywhere any ideas where it might have been going
Old 10-20-2011, 06:37 PM
HeyYou is offline
Check the radiator, and transfer case......
First thing to do is make sure fluid level is up to where it should be, have to check fluid in neutral, checking in park will give a false reading.
Old 10-20-2011, 10:48 PM
96Dodger's Avatar
96Dodger
96Dodger is offline
Checked the tranny fluid in neutral still reading good and no leaks seen around transfer case or radiator seems like it wants to take off but doesnt have enough power
Old 10-20-2011, 11:27 PM
HeyYou is offline
Will it move in any gear?
Might be time to drop the pan, and see if you find anything that shouldn't be there.....
Old 10-20-2011, 11:28 PM
96Dodger's Avatar
96Dodger
96Dodger is offline
It wont move in any gear at all seems like its always in neutral
Old 10-20-2011, 11:30 PM
HeyYou is offline
I would suggest checking pressures, but, my guess is, you don't have a gauge for that. Might be as easy as a plugged up pressure solenoid, have to drop the pan to find out though.
Old 10-21-2011, 04:04 PM
96Dodger's Avatar
96Dodger
96Dodger is offline
what's a good way to see if its plugged up
Old 10-21-2011, 04:35 PM
HeyYou is offline
Drop the pan, pull it out, and have a look...... unless you have access to the right gauge, or a scan tool that will read pressures.
Quick Reply: 1996 Dodge Ram 1500
