lifting my 2wd
Old Nov 3, 2011 | 08:20 AM
  #31
97tn4x4's Avatar
97tn4x4
I put a 2" spacer on a guys 2wd with a 3" body and 35's and it looked pretty good. It was close to being as tall as mine when it only had a 5" lift.
Old Nov 3, 2011 | 11:39 AM
  #32
97_ram1500's Avatar
97_ram1500
i may do that. if not ill do the 6 inch fabtech lift of just spindles/blocks and a 2 inch body lift
Old Nov 3, 2011 | 11:52 AM
  #33
EndIsNear's Avatar
EndIsNear
I think this is a 3" spindle lift and 3" body lift together. The 2" spacer and body lift would look similar if you run 35s:
Old Nov 3, 2011 | 11:56 AM
  #34
97_ram1500's Avatar
97_ram1500
where are yall finding these pictures cause i cant find very many at all. and im just looking to fit 35s with a little flex room. looking for around 5-6 inches of lift.
Old Nov 3, 2011 | 11:59 AM
  #35
EndIsNear's Avatar
EndIsNear
Lol I have a lot on my phone. I search all the time, and save the pic if I like it. Just takes a lot of searching
Old Nov 3, 2011 | 12:09 PM
  #36
97_ram1500's Avatar
97_ram1500
haha oh i bet. im about convinced to just do the 6.5 fabtech or the doestch 6 on 35s.
Old Nov 4, 2011 | 02:10 AM
  #37
joekool4's Avatar
joekool4
97- what kind of rear diff do you have? I have the tow PKG 3.55 stock. I'm running 32s and on the highway it needs a little more OOMFF to get goin to pass anyone. I plan on doin 3.92s or 4.10s before I go anything over 33s.
Old Nov 6, 2011 | 07:48 PM
  #38
97_ram1500's Avatar
97_ram1500
i not positive, but if there is a way to check then i'll run out there and check.
Old Nov 6, 2011 | 07:53 PM
  #39
stewie01's Avatar
stewie01
On the '01 4x2 2.5" is the most you can lift without having to get larger upper control arms right? My question if you level the front end, does that take away from how much you can lift without having to get bigger upper control arms?
Old Nov 6, 2011 | 07:54 PM
  #40
Depends on how you lift it. If you go with longer springs, then yes, you need to replace the control arms. If you do spindles, then, you don't. Its all about operating angles of that upper ball joint.
