Transmission problem while towing?
Old Jan 16, 2012 | 03:45 PM
  #41
SteveM4A1's Avatar
SteveM4A1
No clue. Could be either, or both.... If it is relatively easy to keep up with, I would nurse it till warmer weather came along, or, it started doing something even more undesirable. (odd noises, worse leak, or just quits working altogether.)
I'm crossing my fingers that I can as well. Once warmer weather comes around, I can ride my motorcycle everywhere and then yank my tranny out and service it. I've seen other posts talking about taking the inspection plate off to take a look. Would it help me in this case? I saw where you stated that its not real easy and may not even be worthwhile...
Old Jan 16, 2012 | 04:17 PM
  #42
The inspection plate is at the front of the torque converter, taking it off gives you a nice view of the back of the flex-plate. (or, in moparspeak: Drive Plate.) I don't think you would be able to see anything at all from the angle it would give you......
