Transmission Went Out Today!
when my gov soleniod soleniod failed it wouldnt shift past 2nd gear hot or cold... Have you even checked your fluid?? is it still pinkish red or has it turned brown? how does it smell? burnt? Is there any chance someone poured regular tranny fluid in it instead of ATF4? most mechanics will tell you that will screw them up fast if mixed.
In any case you'd be smart to have a code reader hooked up because even if you get no lights on the dash you will find it is likely throwing a code pointing to the problem...thats How I diagnosed mine.. harbor freight code reader... way easier than blindly guessing and replacing things.... and replace the govener pressure sensor with the soleniod if you do change it. they are supposed to be replaced as a pair as its impossible to tell which is failing.
Mine was throwing a code but the shop i took it to for some odd reason decided to tear apart the whole tranny. there is a good write-up on cleaning and replacing the solenoid in the FAQ/DIY section. And as Auggie said its a good idea to do the solenoid and pressure sensor at the same time.
I don't get i? Were you gonna bolt on a junkyard trans? That wouldn't be good if that's what you were thinking. Why not just drop the trans you have and rebuild that? I can only imagine you'd have to replace the soft parts. That is unless upon inspection, you find that you need some hard parts.
Trending Topics
Get the trans nice and warmed up, so it starts misbehaving. Unplug the 8 pin connector on the drivers side of the trans, shortly behind the shift linkage. Take your truck out for a test drive. You will have to shift manually, as there will be ZERO automatic function. None. If it shifts fine when you tell it to, just replace the governor pressure sensor, and solenoid, and plug everything back in. (adjust the bands while you are in there.) Should be done. No junkyard trans, no expensive rebuild.
Alright so i decided i was gonna go and replace the governor pressure solenoid and sensor. I know that you cant gurantee my problems being fixed but from what i say does it seem like this is the cause. My transmission shifts strong and doesn't slip but just has trouble of knowing when to switch and running 3 grand before it shifts is not good for my wallet or motor.
well it looks like I jinksed myself.... my truck appears to be stuck in limp home mode now.... its raining at the moment but im going to try to unplug the harness and shift manually... figures right before my hunting trip too...
its only been 9k miles since i replaced my soleniod, sensor half the fluid and filter..
