where is this Mess coming from: Coolant Leak.
Old Nov 25, 2011 | 10:24 PM
  #41
BigBlue83's Avatar
BigBlue83
i tryed to spray it with that wrench grease stuff but didnt work i tryed the hammer too to tap shock it into getting past the breaking point.. i second the chance to buy new tools for my vehicle but ive spent two enough money this weekend with double rolling timing chain and hoses and gasket kit and water pump oh i did however pick up a O2 socket too that was useful .... funny story when i was taking off the alternator i had to disconnect the a/c lines that pass over it (i didnt want to bend them) well i didnt know what they were and as i started to undo the bolt it started hissing at me and i was all panicked to tighten them back up...than i found out what it was.. all though i didnt even finish the tear down today im pretty happy with it all and confident i can wrap it up tomorrow
Old Nov 25, 2011 | 10:41 PM
  #42
I removed the A/C compressor first..... just unbolt it, and set it out of the way. (on the passenger side...) there is one bolt that is under the lines, which is a major pain, as I think they hold the axle in place too... they are LONG. No need to bend lines, or discharge the A/C.
Old Nov 25, 2011 | 10:45 PM
  #43
gdstock's Avatar
gdstock
I have my AC compressor moved over to the side and tied up over horns until I can get a friend to recover refrigerant and then tie in to new compressor. Stuff is about $1.00 and ounce, and it takes about 32 oz dry. If you are careful you won't kink the lines.
You will need to add some back in for the lost refrig, but it should not be too much. As it was still under pressure when you tightened it back up, no moisture would have gotten inside. Just do not out in too much. That is the most common problem when people put theri own in, they think more is better.
Old Nov 25, 2011 | 11:52 PM
  #44
UnregisteredUser's Avatar
UnregisteredUser
And then do an AC recharge straight away, of course.
That's where the massive collection of bungie cords comes in handy. A nice long bungie between the compressor and the hood hinge will keep it out of the way nicely. Of course you know this, but some other folks coming along later need to know it but don't. Another bungie from the lip of the cowl forward will keep the alternator nicely out of the way, too.
Be careful with that front/left (looking in from the front) bolt. It both holds the AC compressor and provides fire protection...
http://youtu.be/0MAfDXN45d0
Old Nov 26, 2011 | 11:06 AM
  #45
BigBlue83's Avatar
BigBlue83
Im working in taking of a/c conpressor but having trouble with the connector that goes to the front of it does anyone know the trick or clip to disconnect the connector
Old Nov 26, 2011 | 11:13 AM
  #46
Should just be a little tab you have to lift, and then it should pull straight out. There MIGHT be a red locking tab you have to remove first though.
Old Nov 26, 2011 | 11:18 AM
  #47
BigBlue83's Avatar
BigBlue83
Yes theres a red locking tab I moved that I will look for the tab tryin to find an old tooth brush and clean the damn thing so I can get a look at it thank you
Old Nov 26, 2011 | 04:20 PM
  #48
BigBlue83's Avatar
BigBlue83
How do I get the pulley and harmonic ballancer off? Theres a nut that is 1 an 1/4 inch big I cant get it off im going to the left is it reverse thread
  #49
gdstock's Avatar
gdstock
Those clips tend to get brittle as well. Clean it well, take your time and pull it slowly. I broke the tab on mine and use a tie wrap to hold it seccurely. If it looses, it will arc and loose connection.
Old Nov 26, 2011 | 04:56 PM
  #50
BigBlue83's Avatar
BigBlue83
Any ideas on the nut that goes to the harmin balance? I have the tool but theres a main nut center u have to get to first I tryd breaker bar liquid rench tow straps heat
