Dakota lsd in a 1500?
Old 12-04-2011, 12:45 AM
Relex's Avatar
Relex
Relex is offline
Is there any trick for tightening the adjusters back up? Or just tighten untilthey are snug again?
Old 12-04-2011, 12:53 AM
Terribly's Avatar
Terribly
Terribly is offline
If you take the axles out... there is a special tool you can use to tighten the adjusters. The tool is pretty much a long rod with a big nut welded onto the end (dont know what size nut) to twist the adjusters. Thats the way I did it but my friend is a welder and made the tool
Old 12-04-2011, 12:56 AM
Terribly's Avatar
Terribly
Terribly is offline
Oh do make sure you get the pinion preload and the correct ring gear backlash measurements when you reinstall the assembly!!!!!!!!!!!!!!!!!!!!!!!!!!!! Otherwise you will have a clashing noise when you drive/ accelerate.
Old 12-04-2011, 08:33 AM
Relex's Avatar
Relex
Relex is offline
Does anyone have any insight or have a link on setting backlash?
Old 12-04-2011, 09:02 AM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Download the service manual from the FAQ/DIY section.
Old 12-04-2011, 11:00 PM
Terribly's Avatar
Terribly
Terribly is offline
You're gonna need a dial indicator measuring tool. Im not sure if Autozone will let you rent one as they are pretty expensive
Old 12-04-2011, 11:10 PM
Hahns5.2's Avatar
Hahns5.2
Hahns5.2 is offline
Harbor Freight, sub-$20 IIRC.
Quick Reply: Dakota lsd in a 1500?
