changing oil pan gasket
#41
#42
I bought the pan gasket and rear seal with every intent to do that job after timeing set and kegger mod. But it isn't leaking and I have a lot of other things that need to be done. I am hung in that "if it ain't broke - don't fix it" stage, at least for now. When I get everything else done, I will probably go ahead and do it. And as I drop the pan on the ground, I'll start wondering, "where in the hell did I put that thing?" - - - gettin' old sucks!
I'm glad we have Zman such that we are "shamed" into attempting good maintenance.
#43
#44
#45
Changed pan and gasket and now it leaks
I just changed out the pan and gasket (see pics of old pan which was leaking via rust) and now I have a leak at the rear seal. I followed the info in this thread including the use of RTV. I used an inch pound torque wrench. looking at my garage floor I see a drop every other day. it comes out from behind the trans cover.
I'm thinking of just tightening up the rear most pan bolts to see if it stops the leak. What do you guys think?
#46
