Any tips on a rear main seal install?
Old Dec 19, 2011 | 06:13 PM
sk187's Avatar
sk187
Default Any tips on a rear main seal install?
I removed the oil pan, removed the oil pump, removed the bearing cover that holds the lower rear main seal.
I am currently looking at the upper rear main seal and it really doesnt look like its going to go easy.
Just wondering from guys who have done this before if it was a major pain or if it came out fairly easy and if they had any tips.
The seal isnt leaking but I already have the pan off so I might as well get everything fixed up while I am in there.
I have read the DIY at http://www.pavementsucks.com/tech-article-31.html
Old Dec 19, 2011 | 07:01 PM
Loosen up the rest of the main caps. Don't take them off, just back the bolts out 1/8 to 1/4 inch, so the crank can 'sag' a bit. Then, use some stiff non-metallic object to push the upper part of the seal around the crank. Something like one of the sticks from a box of tinker-toys would work great. (because that's what I used..... )
Old Dec 19, 2011 | 08:02 PM
sk187's Avatar
sk187
That's a great idea I have watched alot of videos and all have said to use a screw driver but dont hit anything metal. I never even thought about a hard plastic object.
Thanks for all your help this is about as far as I have ever been in a gas engine.
Old Dec 19, 2011 | 08:09 PM
mcweaver's Avatar
mcweaver
and it really is as easy as it seems especially if you loosen the other bolts!
Old Dec 19, 2011 | 08:13 PM
plott hound's Avatar
plott hound
i just did mine without loosening any other bolts,totally lucked out.slipped the old one out and had the new one in real fast.
Old Dec 19, 2011 | 08:15 PM
sk187's Avatar
sk187
Excellent.
Alot of instructions to put some RTV gasket maker on the ends, is that something to do?
Old Dec 19, 2011 | 08:17 PM
sk187's Avatar
sk187
Those are the instructions I am using just having trouble figuring out what side of the felpro seal faces the front of the truck they look very similar.
Old Dec 19, 2011 | 08:20 PM
mcweaver's Avatar
mcweaver
maybe your pan is different than mine, but on mine I do remember it was similar but once I got it on the right way it was a definite that it went that way. I think you'll know when it's on right. Again though yours may be different than mine
Old Dec 19, 2011 | 08:30 PM
gdstock's Avatar
gdstock
I think there is a red mark on one side of the seal. Check FSM because I cannot remember which side goes which way.
Old Dec 19, 2011 | 10:32 PM
sk187's Avatar
sk187
did anyone use RTV sealent on anything during this install?
