engine position system performance?
Old Dec 29, 2011 | 07:28 PM
  #31
kejobe's Avatar
kejobe
There is no wire from the coil to the dist. The dist actually has nothing to do with spark timing. The sensor in there controls injector timing. That's it.
I think he was refering to the spark plugs style coil wire.
Old Dec 29, 2011 | 07:29 PM
  #32
DOH!
True, there is that one.........
Old Dec 30, 2011 | 09:53 AM
  #33
sam_priem's Avatar
sam_priem
yea that one.
and as for checking the spark, if i have a weak spark should i lean more towards the crank sensor?
and a question about the timing chain. IF my fuel sync is off, will i be able to change the timing belt? will changing it have any effect of the fuel sync? basicaly what im asking is can i change it while the engine is still having these problems or should i wait until i KNOW the fuel sync is set right?
Old Dec 30, 2011 | 09:58 AM
  #34
zman17's Avatar
zman17
Retired Moderator - RIP
I would check the coil, can be done by looking in a HAynes. And you can set the fuel sync after or before timing chain. Doesn't really matter. I'd try it before just to see what it does.
Old Dec 30, 2011 | 10:00 AM
  #35
I would change the timing set first, and then have fuel sync reset. (reason being, having it set with a sloppy chain will change sync when you replace it.)
If you have consistent weak spark on one or more cylinders, but, good spark on others, crank sensor is where I would look first.
Old Dec 30, 2011 | 10:05 AM
  #36
sam_priem's Avatar
sam_priem
the thing im affraid of is that i dont know how well the fuel sync is set. i dont want to put a new chain on there and have that throw off the fuel sync just enough to not run.... again.
  #37
zman17's Avatar
zman17
Of course I would reset it after the TC change also.
Old Dec 30, 2011 | 10:09 AM
  #38
sam_priem's Avatar
sam_priem
would this spark tester work?
http://www.oreillyauto.com/site/c/de...d=spark+tester
  #39
It would probably just run crappy..... or... crappiER. We had a member that had fuel sync 180 degrees out, and his truck still ran.
And yep, that one will work fine.
Old Dec 30, 2011 | 10:11 AM
  #40
sam_priem's Avatar
sam_priem
i would but if it doesnt run then i gotta get it towed. i dont want to spend $100 to my truck towed 3 miles.
