Tranny problem maybe?
Oven cleaner works good too.... I sent mine to the machine shop to be hot-tanked. But, I had a spare that I was modding, so, could still drive my truck while it was out. (for a friggin month...... race season.....)
I had to replace my cat at about 69K. Drove fine one morning but had it on the highway and noticed less and less power...by the time I made it to the Dodge house (about 50 miles away) I could only do about 20 mph....I thought tranny when it happened to me too.
Wish I had know about the disabling the front O2 sensor.....
SUCCESS!! sort of. I broke a vacuum line. But other then that everything went smooth! Also cracked my throttle body. Wasn't paying attention when i was tightening the bolts. But the crack is in a place that still lets it function properly. Everything else is torqued to spec. I was really surprised how little torque the plenum bolts get. 84 in lbs isnt much at all.
can anyone tell me what it goes to?
http://imageshack.us/photo/my-images/819/dodge4.jpg/
@Tim I did check my tranny fluid again in neutral and it was within the appropriate range.
here is the photo you asked for. Far enough away i hope.
http://imageshack.us/photo/my-images/16/dsc03451o.jpg/
Forgot to check all the hvac settings. But ive got to go return a few burrowed tools to autozone so i will check em then.
Also i have a question about removing the cat. How exactly do you do it? 2 pipes go in from the headers and 1 comes out. If you cut the cat out you would have 3 pipes correct?
Edit: All the hvac controls work. When i get up to a certain speed it seems to change settings though. about 45 mph or so. But its done that before. normally it does it at about 60-65 mph though.
