Oil in the intake...still
Old Jan 2, 2012 | 10:29 AM
romadramowner's Avatar
romadramowner
Default Oil in the intake...still
Okay, so I did the Hughes plenum fix about 7 months ago and at the same time replaced ALL seals and gaskets from the heads up. But it still smoked so about two months ago I replaced the valve seals. That seems to have solved the smoking.
My questions are below:
1. If I had bad valve seals would that cause oil to be inside the intake?
2. I have oil inside the kegger but it was after the Hughes fix so it has to be the valve seals, correct?
3. Do I NEED to clean up the oil or can I leave it since it doesn't smoke anymore?
Old Jan 2, 2012 | 10:31 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Not seals, it may be coming from the PCV valve. Get one from the dealer.
Old Jan 2, 2012 | 11:10 AM
romadramowner
Did that already. But I suppose I could try getting another one since they are cheap.
Old Jan 2, 2012 | 11:12 AM
romadramowner
I'm pretty set on doing the CTD conversion so I don't know if I feel like pulling the intake off again to check. It's not smoking anymore so I wonder if I should just say "screw it" and leave it be.
Old Jan 2, 2012 | 11:22 AM
How much oil do you go thru between changes?
Old Jan 2, 2012 | 11:25 AM
zman17's Avatar
zman17
The intake as in air cleaner assembly? Pull it off and the TB and check that the gasket isn't blown again.
Old Jan 2, 2012 | 12:56 PM
romadramowner
HeyYou,
I really haven't driven it that much due to being out of town and having the oil consumption. I just changed it after I reassembled it after the valve seals. It was previously using two quarts for about 400-500 miles. Maybe even more.
Zman,
I think I may just pull the throttle body and check it. Then if it's leaking, I suppose I can take a few hours and a 12 pack and pull everything off again. If it's leaking then it is likely operator error rather than poor design by Hughes.
Old Jan 2, 2012 | 01:04 PM
zman17's Avatar
zman17
7 months is sure long enough to know if you did something wrong. It shouldn't be leaking if everything was done right.
merc225hp's Avatar
merc225hp
Have you done a leak down test or a comp test to see what shape the motor is in? It might not be the gasket it could be blow-by past the rings etc. Best is to see were the motor stands before tearing it apart.
Old Jan 2, 2012 | 05:27 PM
romadramowner
Merc,
I have not done those tests, however, it no longer smokes after fixing the valve seals. Would those tests be relevant to why there's still oil in the kegger? I haven't performed those before, that's why I ask.
Brandon
