changed header gasket now no start
Old 01-19-2012, 10:19 PM
sam_priem's Avatar
sam_priem
sam_priem is offline
Originally Posted by BackwoodsRam
Nvm about the black box. Is there any way I can check fuel sync at home
not anyway that i know of. unless you know someone with the DRB II scan tool. or the OTC genisys. <--thats what i used to set mine. but you may have to take it to a dealer and have them check it.
Old 01-20-2012, 12:10 AM
fargo39's Avatar
fargo39
fargo39 is offline
did the ground wire at the front of the engine driver side come loose? maybe it's flooded did you try holding it to the floor and starting it
Old 01-20-2012, 01:02 AM
gdstock's Avatar
gdstock
gdstock is offline
Edit. The confusing thing is that I didn't mess with the distributor at all until after the issue popped up. I just can't figure out what could be causing my problem. I have fuel and spark and the starter turns the motor. Tue truck just won't start
OK. So now I am confiused.....The fuel synch is OK "if" you did not pull or turn the distributor. What do you mean by "didn't mess with the distributor at all until after the issue popped up.." What did you do to distributo and when did you do it? Info is not clear.
Old 01-20-2012, 08:48 AM
BackwoodsRam's Avatar
BackwoodsRam
BackwoodsRam is offline
All I did was remove the cap and rotor. Fuel sync was just a guess because I have fuel and spark
Old 01-20-2012, 09:19 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,391 Likes on 3,131 Posts
Check your firing order.
Old 01-20-2012, 09:22 AM
BackwoodsRam
It's good. I checkedit several times
Old 01-20-2012, 09:24 AM
HeyYou is offline
Something get pulled loose?
Old 01-20-2012, 09:26 AM
Sheriff420's Avatar
Sheriff420
Sheriff420 is offline
Swap the ASD relay with the fog light or horn relay and try again.
Old 01-20-2012, 09:27 AM
BackwoodsRam
Not that I can tell. The motor ran for about 10 seconds on the passenger side bank yesterday and then cut off. Then I remembered I never plugged the drivers side sparkplugs back in. after I plugged them back in the motor wasting start at all. I'm ring to figured out what damage was done due to running it on one bank of cylinders
Old 01-20-2012, 09:28 AM
BackwoodsRam
Did that a couple of times. Man this truck is ticking me off
Quick Reply: changed header gasket now no start
