changed header gasket now no start
Old Jan 20, 2012 | 07:35 PM
  #41
BackwoodsRam's Avatar
BackwoodsRam
Well I installed the Dakota PCM and no change. Still no spark. I'mthinking that I got an incorrect PCM i'm gonna go back to the JY tomorrow and hopefully get a PCM and coil from a ram
Old Jan 20, 2012 | 07:48 PM
  #42
Grab the crank sensor as well.
Old Jan 20, 2012 | 07:52 PM
  #43
BackwoodsRam
Will do. I thought if I had power at the coil and injectors then that Kent the crank sensor was good?jw. Ate there any other parts that could cause a no spark condition?I just wanna make sure I can grab everything in one trip
Old Jan 20, 2012 | 07:53 PM
  #44
That's all I can think of......
Old Jan 20, 2012 | 08:03 PM
  #45
BackwoodsRam
Thanks. Hopefully tomorrow my truck will be running tomorrow
Old Jan 20, 2012 | 08:07 PM
  #46
redneck_ram's Avatar
redneck_ram
dontcha just love auto correct?? hope you get it fixed soon. im betting the crank sensor got fried.
Old Jan 20, 2012 | 08:23 PM
  #47
BackwoodsRam
Fixed the auto correct lol. Hopefully that's it. I'm tired of changing parts while i'm sick
Edit how much should the tach jump when I try to start the truck?
Old Jan 20, 2012 | 09:21 PM
  #48
sam_priem's Avatar
sam_priem
depends on if the engine is cold or not. when its cold mine goes to about 1500. when its warm it goes to around 1000
Old Jan 20, 2012 | 09:59 PM
  #49
BackwoodsRam
I meant before the motor starts. How much does the tach jump when only the starter is turning the motor
Old Jan 20, 2012 | 10:32 PM
  #50
fargo39's Avatar
fargo39
you said you had power at the injectors?do you have a ground pulse when you turn the engine over? if you don't have a noid light 'injector light' a simple way to check if the injector is firing is take a 194 bulb,marker light bulb bend the wires out. unplug a injector,push the two wires from the bulb into the plug and turn the engine over. see if the bulb flashes. a led test light works good for testing injectors and with a led test light you can see if you have a ground pulse at the coil. could save you time running to the junk yard.
