trans temp
Old Feb 26, 2012 | 09:32 PM
  #41
SilverSS's Avatar
SilverSS
Originally Posted by zman17
It won't hurt the tranny running cool. If it is too cold it just won't shift into OD.
I thought the ideal temp for auto transmissions was around 180*?
Old Feb 26, 2012 | 11:06 PM
  #42
That was my understanding as well.
On my 96, I sure don't have to drive it far when it is bitter cold out, before it will hit O/D though...... wonder if that was an advent of later years, or, my temp sensor is just lying to the PCM.
Old Feb 27, 2012 | 12:31 PM
  #43
zman17's Avatar
zman17
Retired Moderator - RIP
Old Feb 27, 2012 | 03:31 PM
  #44
SilverSS's Avatar
SilverSS
I've seen that chart before but it doesn't mention under 175*. I know the Earl's cooler in my car has some sort of thermostat that bypasses fluid when it's below 180*.
Old Feb 27, 2012 | 05:22 PM
  #45
crazzywolfie's Avatar
crazzywolfie
this is what i was thinking about using on my 81. $8 in fittings.
Old Feb 28, 2012 | 09:35 AM
  #46
chadhager03's Avatar
chadhager03
It's a high pressure line and I'll bet it'll blow those slip on lines off one day. I used one hose clamp and it blew if off in the parking lot and I had to get a ride to get 5 qts of ATF, so now I have three hose clamps and 2 zip ties on the line and 5 qts of spare ATF in my tool box.
Old Feb 28, 2012 | 10:12 AM
  #47
crazzywolfie
maybe the newer trucks have higher pressure lines but both of my trucks have at least 2 rubber lines that are hose clamped on. i think with the correct hose clamps and high pressure hose i will be ok.
Old Feb 28, 2012 | 11:48 AM
  #48
zman17's Avatar
zman17
Sorry, but the sending unit is so far out of the flow of fluid, it's pretty much useless. Been there done that. That's why I suggest getting this. It's worth it.
http://dieselmanor.com/dm_products/FTG-MFD.asp
Old Feb 28, 2012 | 01:34 PM
  #49
UnregisteredUser's Avatar
UnregisteredUser
Worm drive hose clamps have to be re-tightened after the first heat cycle, and then again after a few more heat cycles -- or they'll leak pretty much every darn time. It might take them a while to get started, but they'll leak eventually if you don't touch them twice after installation. After the second tightening, they'll hold on tight for years and years.
Old Feb 28, 2012 | 01:50 PM
  #50
chadhager03
You learn something new every day. Thanks, I'm Going to go tighten all of my hose clamps again
