what do our trucks like?
Old 02-05-2012, 03:17 PM
Wombat Ranger's Avatar
Wombat Ranger
Wombat Ranger is offline
^^^ ah haell yeah!!!
  #22
Old 02-06-2012, 07:45 AM
UnregisteredUser's Avatar
UnregisteredUser
UnregisteredUser is offline
Originally Posted by Augiedoggy
Dont expect any more hp or torque from the expensive tuneup parts like wires cap rotor or plugs...
The truth has been spoken! Also, don't expect any benefit from high zoot coils unless you're actually taxing the stock ignition in some way, which most of us just ain't doin'. If you're not blowing well past the factory rev limit or knocking around at high elevation, just leave the damn ignition unmodified. It'll do what needs doing.
  #23
Old 02-07-2012, 12:55 AM
mike.97.2500's Avatar
mike.97.2500
mike.97.2500 is offline
so wow i totally sparked a little heated discussion but i figured this kinda would so first off i have thought about doing a cam but wont for ahile do to the fact that most motors iv looked at have a warranty on them and they would be voided if i drop in a cam so a future mod yes but not now. as for plugs and wires i know im not gonna gain anything special from that i just really want to get away from the stock issues it has and more or less be able to forget about it thats wh i was looking for advice on that stuff maybe i was thinking wrong but i just figured msd is a big name yes they cost more than others but maybe ill get what i pay for and be able to forget about the problems.
i do live in high altitude im in colorado springs co i think we sit somewhere around 6,xxx somethin so altitude is something for me to consider.
i have considered all kinds of stuff and intake, fuel, spark and exhaust are all being redone. i was hoping people would just know what was the best to use for those upgrades i know alot is preference but hopefully some info on what has been used and works good.
  #24
Old 02-07-2012, 01:11 AM
merc225hp's Avatar
merc225hp
merc225hp is offline
Instead of me posting a huge list of parts have a look at the link, I have zero compants about any of the parts listed, if you need part numbers I can post those for you just ask.
https://dodgeforum.com/forum/garage/...merc225hp.html
There is a diy area with polls in it for what some are using for parts you might want to have a look there as well.
Sorry your thread took a turn for the bad.
  #25
Old 02-07-2012, 01:17 AM
gdstock's Avatar
gdstock
gdstock is offline
Originally Posted by zman17
The dice add plenty of power, but I will say , the HS 1.7's added a little more.
zman! Gotta have the HS rockers, the fuzzy dice, AND Name:  hula.jpg
  #26
Old 02-07-2012, 03:52 AM
mj23polaris's Avatar
mj23polaris
mj23polaris is offline
Booooost!!!!
  #27
Old 02-07-2012, 09:06 AM
UnregisteredUser
I was thinking more Leadville or Trail Ridge Road than the Front Range when I said "high elevation". If you're not seeing misfires at those elevations then you don't have a problem. If you do get misfires it'll likely be at very high elevation on hot days when asking the engine to work at low RPM, which is when you'll have a thin, wispy mix that isn't well atomized. The fix for that is a system that'll let you crack your plug gaps out beyond .050", and of course plugs that aren't bent out of shape to get there.
That said, I did upgrade my ignition so I can run expensivum plugs with huge gaps, both for high elevation (>10,000') and to get my tune up interval out to 80,000+. I took the approach of getting one great big mufker of a spark rather than several little ones -- the plugs last longer that way, if nothing else. YMMV.
  #28
Old 02-07-2012, 09:47 AM
BackwoodsRam's Avatar
BackwoodsRam
BackwoodsRam is offline
Originally Posted by Wh1t3NuKle
What e-fan would equate to RRs, because I'd like to know.
Let's say an e-fan setup is $150 as that is one you hack together, like ford fan from JY, get the controller for cheap, so now its $200 for a cam? What cam would that get you?
my efan set up is from a 01 jeep grand cherokee and was only 50 buck, i already ahd the stuff to wire it up. and it keeps my motor plenty cool
Originally Posted by 2x1972
That and Fuzzy Dice.
everybody knows that fuzzy dice add like 500 hp and 600 lb-ft
op if you want lots of power build yourself a supercharged 408 stroker...yea its pricey but itd be wayyyyyyyyyyy worth it
  #29
Old 02-07-2012, 10:05 AM
Augiedoggy's Avatar
Augiedoggy
Augiedoggy is offline
I member here, ("CMCKENNA" I believe it was) who is very thorough in testing actually tested a bunch of various wires from different brands such as "MSD" he posted the results and I (As well as him) were surprised at how poorly the MSD wires actually tested against others including much cheaper wires... I will see if I can dig up the thread.
Here is is...https://dodgeforum.com/forum/2nd-gen...k-wires-2.html
  #30
Old 02-07-2012, 11:06 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Wh1t3NuKle is offline
Originally Posted by mj23polaris
Booooost!!!!
^this
Quick Reply: what do our trucks like?
