Suggestions for lift and other things on my ram
Old Mar 12, 2012 | 05:06 PM
  #41
The thick cut gears are for use on the 4.10 and down carrier. (which I would guess is what you have.)
A selectable locker for the front would be a better plan, albeit, more expensive.... ARB, or something similar.....
Old Mar 12, 2012 | 05:54 PM
  #42
merc225hp's Avatar
merc225hp
It was me that said I have killed a couple of Detroit lockers but that was in the rear diff, I have never had any problems with the front DL, and the one's that did go bad were replaced on warranty. I am extremely hard on my truck in the winter, deep wet snow can and will find any weak part and kill it fast. ARB are very nice parts and would be the best for a more DD over the DL.
Old Mar 13, 2012 | 01:37 AM
  #43
P1NKST@FF's Avatar
P1NKST@FF
I'd love to do ARBs, but theyre ove $1000 an axle
and I have 3.55s I guess thats what you were talking about hey you.
Also I dont know what axle I have in the rear, Yukon site said non circular (don't know what shape) diff cover meant 9.25 (I think, I know it was 9something) but ARB site says I have 8.25
Old Mar 13, 2012 | 02:06 AM
  #44
merc225hp's Avatar
merc225hp
Sorry to say but no ARB for the Dodge 91/4 rear diff, But you can get the ARB for the Dana 44. Please add 1500, 2500 or 3500 to your sig
Old Mar 13, 2012 | 02:10 AM
  #45
P1NKST@FF's Avatar
P1NKST@FF
So I do have 9 1/4. guess I'll start on the rear with a detroit and keep it out of 4wd till I can afford the front and decide from there. Thank you
Old Mar 13, 2012 | 02:33 AM
  #46
merc225hp's Avatar
merc225hp
You are Welcome.
You can always put the new gears in the front to match the back without installing a new front Dl or some type of locker in the front, then when you can afford the locker for the front then just switch the gears to the new Dl or locker when you get one. That way you can still use 4x4.
Old Mar 13, 2012 | 03:43 AM
  #47
P1NKST@FF's Avatar
P1NKST@FF
If I try to put in the new differencial after the ring and pinion won't I have to get the backlash reset again? I know its not something I have the skill or pacience for so I dont really want to have to pay for it twice ya know, unless you don't have to....
Old Mar 13, 2012 | 06:23 AM
  #48
P1NKST@FF's Avatar
P1NKST@FF
I found for the cost to go to Dana 60-80 diff's with all the goodys that I would run the cost was about $3500 to me this was just not worth it. Instead I am going to uni-mog portal diff's, they cost about $2500 each used with factory air lockers, they add 4" of lift and ground clearance, not cheap by any means but I think they are a much better investment than Dana's. The rear diff is ready for me to pick up and the front diff will be ready in May, if all goes well they will be installed in the fall. Might not be under the black truck but a 2nd gen none the less.
Example pix of portal diff's
Are those axles set up to just bolt underneath your truck or do you have to a lot of work to get them to fit, I think they are about the wildest set up I've ever seen and I see almost no drawbacks to them
Old Mar 13, 2012 | 07:04 AM
  #49
Wombat Ranger's Avatar
Wombat Ranger
As with any axle swap, custom brackets must be welded into place. Also special consideration must be taken when building a link-style suspension, as the portals put massive amounts of leverage on the links, and will break them if not correctly set up.
Old Mar 13, 2012 | 02:44 PM
  #50
merc225hp's Avatar
merc225hp
These are not a bolt in diff by any means. That said I am having them built to be just a bolt in but that added about $500 per diff to get set-up to bolt in. New spring mounts, new link brackets, centered pumpkin for the rear diff, convert to disc brakes is the real wallet killer. The cost is very big but I think it is well worth it in the long run. As I get them I will take pix so you can see what work is involved. I might do a DIY if there is any interest from other members.
Edit: This is going to be a long project I figure about a year before all is said and done, The truck they are going under is a 96 rc/sb 2nd gen, Keep your eye's open on what motor will be going in it.
Hint BBM Hemi,203/205 double down t case set-up
