Kegger Mod
Old Mar 5, 2012 | 09:33 PM
ramthis9501's Avatar
ramthis9501
Default Kegger Mod
Few questions about it... I have an extra intake laying around and want to cut the runners and use it. Thing is I have an 01 but the intake is off a 95. I know I have to cut the plate in the middle and plug the egr valve. How do I plug the egr valve? Also there are some extra ports on the 95 intake. Refer to the pics below. There are three ports on each side on the 95 intake which Im guessing are for vacuum, and only 2 on the drivers side and 1 on the passenger side on the 01 intake. What do I need to do about those?
Thanks in advance
Heres the pics
95 intake
Drivers side
Passenger side
01 intake
Drivers side
Passenger side
Old Mar 5, 2012 | 09:35 PM
Just put an EGR block off plate where the EGR valve would mount, and that will take care of that.
As for the ports, just put caps on the ones you don't need to use. Parts store will have 'em. Also, you will have an extra hole for temp sensor. Plug that too. (pipe plug. get one at the hardware store.)
Old Mar 5, 2012 | 09:36 PM
ramthis9501
Awesome man thank you very much!
Where can I get an egr block plate?
Old Mar 5, 2012 | 09:41 PM
Might be able to get one from dodge....... Of course, they prolly want a hundred bucks for it....
Check the local parts store. They should be able to come up with one for ya. Ask for one for a 95. If you ask for one for an 01, they will never find it.
Old Mar 5, 2012 | 09:50 PM
ramthis9501
Screw the stealership lol I'll call the parts store tomorrow and check it out, thanks again dude!
Old Mar 5, 2012 | 09:52 PM
Hey now, none of that. It's the dealerships job to screw YOU. Don't be reversing roles, the union won't like that.
Old Mar 5, 2012 | 10:01 PM
ramthis9501
Lol my bad... So just to make sure...
In order to make it work, cut the middle plate out, cover the egr with a plate, and seal up the extra vacuum holes and I'll be good right?
Old Mar 6, 2012 | 02:57 PM
silverram2000's Avatar
silverram2000
i have been reading about the kegger mod. one question... i have a parts truck with the 5.2l, does anyone know if i can mod the 5.2 and use it on a 5.9?
Old Mar 6, 2012 | 03:10 PM
merc225hp's Avatar
merc225hp
Yes it will fit the 5.9.
