Never heard of this one either. Weird..seems like it would have to be vacuum related or electrical...some kind of short between the brake switch and something?
4 wheel anti lock I'm not sure of and no it will not start with me foot on the brake. going to pull the wire off of the brake switch and give it a try.
i think i'd unplug all things electrical associated with the brake and see if it changes anything. brake light switch at the pedal or maybe the fuse. abs fuse.
ok yes it has 4 wheel abs and I removed the wire from the switch it didn't stall. Now I have to trace the wires I'm thinking and I hate electrical systems.
Ok removed the fuse and it didn't stall,put the fuse back in and removed the stop-headlight relay didn't stall removed both didn't stall put them back in hit the brakes it stalled
