Stalls when I hit the brakes
Old 03-24-2012, 11:53 AM
dodgerules-othersdroll's Avatar
dodgerules-othersdroll is offline
Default Stalls when I hit the brakes
I have a 94 2500 5.9 4x4 I replaced the fuel pump twice and the crank sensor also. Now when I hit the brake pedal the truck will stall out. The truck runs great till I hit the brake the harder I hit the faster it stalls, even in park. Thanks for your help
Old 03-24-2012, 12:03 PM
HeyYou is online now
Dodge Forum Administrator
Received 3,298 Likes on 3,044 Posts
Disconnect, and plug.... the vacuum line to the brake booster. See if it still does it. (test in your driveway, it will take some real effort to make the brakes stop the truck.)
Old 03-24-2012, 12:41 PM
Ok disconnect it from the booster side and plugged it and it still stalled.
Old 03-24-2012, 12:43 PM
Probably an electrical issue then....... Hows the battery/charging system?
Old 03-25-2012, 09:10 AM
The battery is newer and it's showing around 14 volts.
Old 03-25-2012, 09:14 AM
What's it do when you step on the brake? If you hold a little on the gas, will it stay running?
Old 03-25-2012, 10:15 AM
nope it still stalls the motor. I had it up to 3500 rpm and held the brake pedal down and it stalled.the truck idles and revs up ok till I hit the and hold the brake.
Old 03-25-2012, 10:46 AM
Now I'm thinking the torque converter maybe locking up. Does this sound like right?
Old 03-25-2012, 11:06 AM
Wouldn't matter in park. Does the engine just STOP, or is it akin to turning off the ignition? Any loud noises associated with it?
Old 03-25-2012, 11:25 AM
First thanks for your help. No noises and it just stops. If I let off the brake the motor will run.
Quick Reply: Stalls when I hit the brakes
