46RE slipping after filter/fluid/gasket
Old Apr 7, 2012 | 03:24 PM
  #81
Green vacuum hose is just the vent line for the 4x4 switch on the t-case. It doesn't actually go anywhere.
If you put the truck all the way down into low, will it actually move?
Old Apr 7, 2012 | 05:22 PM
  #82
moss500berg's Avatar
moss500berg
Yeah it'll move, it drives fine forward, it goes through all the gears and locks up the TC like it should around 50mph, it doesnt engine brake worth a damn though when i put it in the lower gears.
Old Apr 7, 2012 | 07:05 PM
  #83
Have a chat with your rebuilder.
Old Apr 7, 2012 | 07:35 PM
  #84
moss500berg
I gave him a call and he said to bring it by and he would look into it.
Old Apr 10, 2012 | 08:55 AM
  #85
moss500berg
He said that theres a check ball that may or may not supposed to be in there, that he put in there. He said he knows for a fact that mine did NOT have one there to begin with but he put one there anyways. He has the truck right now and im supposed to call him in a little bit around noon to see what he's discovered. Hopefully that cures it.
Old Apr 11, 2012 | 09:37 AM
  #86
Have a look here.
Old Apr 11, 2012 | 09:40 AM
  #87
moss500berg
Its fixed now, appearently there is'nt supposed to be a check ball in one of the valve bodies there in some years of the trannies and the others do have it. It keeps it from going into reverse and cuts down engine braking. But now everything is fine and well.
Except my CAD doesnt seem to be hooking up, i can put it in 4Low and it will gear down the rear end but the front is still free wheeling. There was two vacuum hoses or something that go into the lines bolted to the trans x-member, that run the the CAD box, i just dont know if i have them in right or not. Theres a red one and a black one
Old Apr 11, 2012 | 10:16 AM
  #88
moss500berg
Alrighty, thanks man. Ill get down there and see what i can come up with, i probably have the vacuum lines reversed.
Old Apr 11, 2012 | 10:45 AM
  #89
Ohio Mossy Oak's Avatar
Ohio Mossy Oak
From: Born,raised and currently reside in eastern Ohio
Originally Posted by moss500berg
This is how i spent my Sunday
Did ya get any in that catch pan????
Old Apr 11, 2012 | 10:47 AM
  #90
moss500berg
The catch pan was for the oil filter we had to take off. We wanted to keep the space underneath the truck as clean as possible while we still needed under it, once we got the tranny out though, no holds barred haha
