Whats wrong with my truck???
#21
#22
I was able to get the outer bolt (closer to the fender) out without any tricky stuff from underneath, then, since I have an EGR tube in the way, I positioned the allen wrench in between the block and the tube (sticking up long ways), got out from under and went at it from up top, and it came out that way.
#24
#25
#26
Finally getting around to changing this out. So I got the two bolts out and I'm pulling on it.. it moves but doesn't just pop out. Not meaning to sound like a puss but i don't wanna break it and cost myself more money because of it. so does it pull straight up or what?
#27
#28
#29
Im having a similar problem with my truck, I replaced the IACV the first time and that fixed it, and now its doing it again, exact same symptoms as before. My o2s are probably shot, well, one of them probably is, i believe i have an o2 sim on my post-cat o2 plug (little tiny black box with a blinking red light on it, plugged into where the o2 should be).
I can see if my IACV is dirty and clean it up if need-be. Or do you suggest i do something else?
