Whats wrong with my truck???
Old 04-10-2012, 04:43 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Originally Posted by A_POLVADO
Hey I said I was sorry It will never happen again
That was a long time ago bud, we are good now remember?
  #42
Old 04-10-2012, 04:52 PM
zman17's Avatar
zman17
zman17 is offline
Originally Posted by Augiedoggy
and resetting the PCM will do nothing for replacing the CPS....
You are not implying that I said resetting the PCM will help make it easier to replace the crank sensor are you? All I meant is that the negative battery cable should be disconnected before doing any thing that involves replacing sensors or any type of electrical component replacement. And while the procedure is performed and the cableis disconnected, the PCM will be reset upon re installation of the cable.
  #43
Old 04-21-2012, 04:57 PM
kheid9293's Avatar
kheid9293
kheid9293 is offline
New Member
My 97 dodge ram 5.9 is throwing the same code. p1391
About 3 months ago i replace the motor with a NEWER one, new torque converter, sensor in tranny, new distributer, coil, cap, wires, plugs, cmp, ckp, basically everything that can be done on outside of motor is NEW!!! Even with new ckp, cmp, it is still throwing the code. when i take off from a light it shifts fine through first an second, then when it shifts to 3rd at about 40-45 mph it will drop back to second then a sec later will shift again an its fine till i start over again. This does not happen everytime but its something that i would like to get fixed cause it is my only means of transportation. Answers would be awesome thanks.
  #44
Old 04-21-2012, 05:45 PM
zman17's Avatar
zman17
zman17 is offline
What sensor in the tranny did you replace? And did you remove the negative battery cable while doing any work to let the PCM reset? And what brand sensors like the crank sensor did you buy?
Quick Reply: Whats wrong with my truck???
