Problems with used RAM 1500?
Old Apr 7, 2012 | 09:19 AM
Don't use 4x4 on dry pavement. That can get expensive.
Old Apr 7, 2012 | 09:23 AM
chadhager03's Avatar
chadhager03
Also check to see if the heat works, It slips your mind when it's hot outside
Old Apr 7, 2012 | 11:51 AM
musclecarguy91's Avatar
musclecarguy91
This may sound stupid but check to see how the tires are worn. Like if they are more worn on the inside or if they are bald. Tires can be expensive for a truck. Least they are for 2500's
Old Apr 7, 2012 | 02:32 PM
Wombat Ranger's Avatar
Wombat Ranger
Originally Posted by 95Erokram
my 95 has 160k and no cracked dash. to my knowledge it didnt happen til 97-98 when cheaper plastic was used. happened in the pt cruisers and a few others in the same years.
Pretty sure it was all 2nd gen rams that had cracking dash issues, just some area's are less prone due to less sunlight. Example: My '95
Old Apr 7, 2012 | 03:39 PM
chadhager03
+1 on tires, mine were $1100 for bf Goodrich all terrains stock size
Old Apr 7, 2012 | 07:46 PM
Moparman59's Avatar
Moparman59
Default Leakage
The one thing not mentioned here is water leaks. Around rear window corners and same at front windows. Also that lovely camper--brake light at rear of roof. I spent a few bucks tearing out interior more than once to search and repair water leaks.
Old Apr 7, 2012 | 08:06 PM
I haven't had any problems with water leaks in mine........ (knock on wood.....)
Old Apr 7, 2012 | 08:13 PM
stewie01's Avatar
stewie01
I've had some wet floor from a leaky heater core, but no water leaks!
Old Apr 7, 2012 | 08:36 PM
RSDodgelover's Avatar
RSDodgelover
I believe all of the probable issues hve been mentioned but if that one doesn't work out, I have an 01 with 113,000 miles I am thinking of selling. PM me if interested, I am near Seven Springs.
Old Apr 7, 2012 | 09:21 PM
lastrights's Avatar
lastrights
No Sct Tuner for 95 because no ports
