Building a 5.2 for boost
Old Apr 12, 2012 | 09:15 PM
  #31
Hahns5.2's Avatar
Hahns5.2
Here's what's left of a 5.9 after boost and an SCT toon (dyno tooned, not even the hokey email toons). It had about 1000 miles on the toon.
The choice is up to you, but I would get as far away from the stock computer as I can with boost.
Old Apr 12, 2012 | 09:56 PM
  #32
SvrdRam's Avatar
SvrdRam
Originally Posted by CPTAFW163
That was with a SCT tune, however the truck was dyno tuned with the tuner PRESENT during the dyno pulls to make changes on the fly.
Also, you will need new injectors despite having a regulator. The 6AN rails are really just for show.
Yes, I know all about upgrading the injectors. But I have the fuel system in place and ready to go, no issue with supply.
Figured it was dyno tuned, nothing new for me. Had my diesel on the rollers a few times.
Old Apr 15, 2012 | 01:12 PM
  #33
SvrdRam's Avatar
SvrdRam
Motors apart and at the machine shop being cleaned up and checked out. After talking to the guy lastnight turns out rods are in decent shape but he highly recommends me getting some eagle rods like I had planed, bolted on the ARP main studs and line bored, going to be doing the bore and hone with torque plate tuesday.
I just need to figure out what compression I want to run in this thing. 93/+ octane isn't a problem, should I stick with 9:1 or bump it up alittle? Pistons are going to be custom so my options are endless...
Old Apr 15, 2012 | 02:46 PM
  #34
I wouldn't go much over the 9:1 if you are gonna boost.
Old Apr 16, 2012 | 12:24 AM
  #35
CPTAFW163's Avatar
CPTAFW163
863 ft lbs of torque. what is the tranny made of!!
BTW, what is the most HP/Torque that you can get on a diesel (say a CTD from a 2004 Dodge Ram) with a bullydog tune and Propane injection?
Old Apr 16, 2012 | 08:24 AM
  #36
SvrdRam's Avatar
SvrdRam
Stock trans, its my 6.0 f350...stock expect a hot burned fuel injector control module, sct tune, head studs oh and a new flexplate... Name:  imagejpeg_2_8-1-1.jpg
A 24 valve common rail motors are stout motors. My buddy had one in his OBS ford that runs HARD!
http://www.youtube.com/watch?v=bJK5o...e_gdata_player
