Probably tradin' in the Dodge
#21
That is another reason why I decided on the manual transmission in case I decide to tune it down the road.
Been reading up and hands down the Cummins easily surpasses the Duramaxes.
I am actually happy to stick with Dodge because you can actually get to things when you have to replace parts or do maintenance.
#22
I remember the days when I could look under the hood, and actually SEE the parts I wanted to work on....... then came the 70's and 80's, and the engine was hidden under a bag of snakes. (and the rubber hose industry was making TONS of money....) Now, instead of rubber hose, we have wiring harnesses.
#24
Dont go over the top with mods because itll just lead to more problems. Definitely on a high mileage motor. My buddy has a 02 24v 6 speed that had 280k on the motor he paid $10k for.He put water meth $400, quadzilla chip $499, cai $200 and a cfm+ intake $500.He blew a head gasket so he had the head machined and fire ringed $600, head studs $500. Then a month later he blew another head gasket, had a bad one. So we replaced it again and a week later he snapped a wrist pin and spun a main bearing. 160k mile replacement motor $1500.
To sum it up hes 15 grand into a truck thats worth about 8 or 9.
#25
I need this truck to be dependable and last!
#26
The old 5.9 CTD were solid, the new 6.7 Im not sold on, the weekest link in a HD pick up really is the Name dodge, thankfuly the aftermarket has parts to rebuild weak and failing mopar componants.
Sad reality is all HD trucks from my Dodge to a Ford and GM duramax will incure major expenses down the road when the warenty is over.
One Major item to look at with a 3rd gen Dodge solid axle front end is the drag link, the ball joint inside will dry out ( constant need of greae ) and when it goes, pop gos your stearing control.
#27
The good thing of replacing Dodge with Dodge, Is I know what to look for replacing my drag link and track bar 3 years ago.
Another good thing is Dodges sit high off the ground so I want to see the look on the sales person face when I go back to my car and return with my creeper to look over the whole chassis.
Could provide to be a valuable bargaining chip when negotiating price!
#28
#29
on
Damn rust.....
