timing chain help
Old 04-17-2012, 02:21 PM
johnnyjaws98's Avatar
johnnyjaws98
johnnyjaws98 is offline
Default timing chain help
im being told to put timing gears dot to dot on compression stroke or does the dot go on top i need pics please~~
Old 04-17-2012, 02:23 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,212 Likes on 2,963 Posts
If you haven't taken the old ones off yet..... look for the dots on those, and line 'em up, dot to dot. Then, just pull 'em off, and put on the new ones WITHOUT moving anything. If you already took off the old ones, put 'em back on..... and line up the dots.
Old 04-17-2012, 03:11 PM
johnnyjaws98
i already had the chain off when i 1st did it they were dot to dot and put it back on that way and wont idle and pinged i was told to put it on compression stroke on # 1 but when i do timing mark is at top on the cam gear the rotor is pointing to # 1 like this if i put the marks like they should it will be its on the exhaust stroke and rotor is at # 6
Old 04-17-2012, 03:20 PM
merc225hp's Avatar
merc225hp
merc225hp is offline
All the info you need and more is in the fsm even pix.
Old 04-17-2012, 03:30 PM
gdstock's Avatar
gdstock
gdstock is offline
It should look something like this (dot on crank gear is hard to see, but it is there). If #1 is at top and rotor is pointed wrong, I suspect you are on exhaust stroke instead of compression.
Old 04-17-2012, 04:08 PM
johnnyjaws98
what is fsm
Old 04-17-2012, 04:14 PM
stewie01's Avatar
stewie01
stewie01 is offline
Originally Posted by johnnyjaws98
what is fsm
Factory Service Manual.
Available in the DIY Section on here.
Old 04-17-2012, 05:25 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Wh1t3NuKle is offline
what is fsm
You're in here > 100 post and haven't been smacked by Zman for the FSM?
Something is wrong. However, you really should have had your own Haynes manual in the first place. But going plug n play style might work.
Old 04-17-2012, 06:00 PM
HeyYou is offline
I have seen more than a couple timing sets that when the gears are dot to dot, number 6 is in firing position, not 1.......
Old 04-17-2012, 06:05 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
OMG, not another one. Timing chain is easy as hell if you do it right to begin with.(per a Haynes or the FSM) Tear into blindly and good freakin luck. With tc cover off, rotate crank until dots line up on OEM gears,(doesn't matter what piston is where) remove said gears. And replace with new ones. Replace seal and cover. Done. If you rotated the cam or crank , time to start over. (before damage is done)
http://www.bionicdodge.com/Download/...uel%20Sync.pdf
http://www.moparchat.com/forums/showthread.php?t=96310
Quick Reply: timing chain help
