tranny fluid change, what a nice surprise.
Old May 3, 2012 | 11:53 AM
billcart's Avatar
billcart
Do all the gears shift normally?
Old May 3, 2012 | 11:54 AM
ramitt360's Avatar
ramitt360
Right now i have no way of getting to a shop or anything. However i plan on changing my fluids again in about 2 weeks. I read somewhere on here someone recommending doing that IF you haven't kept up on the fluid change. When i change it for a second time i could replace the solenoid. As for adjusting, I have not a clue and would probably eff myself in the A
Old May 3, 2012 | 11:57 AM
ramitt360's Avatar
ramitt360
Gears go through up and down just fine, no problems with normal driving. Just the problem with upshifting when i floor it and the first start and go of the day. After the first start theres no hesitation of any kind when put into gear.
zman17's Avatar
zman17
Retired Moderator - RIP
Order one of these in the meantime , and install it next time you drop the pan.
Old May 3, 2012 | 12:02 PM
ramitt360's Avatar
ramitt360
Yes, I tried to get one from autozone but they didnt have one. Also someone there said DON'T do that! He said something about it being pressurized and putting a plug in would be catastrophic.
Old May 3, 2012 | 12:04 PM
zman17's Avatar
zman17
LMAO... reason 1001 to not shop at Autozone. Unless wax or oil is on sale. Do NOT buy the gov solenoid at AZ.
Old May 3, 2012 | 12:08 PM
ramitt360's Avatar
ramitt360
haha alrighty then. I like the 2 for $5 break cleaner deals there
Old May 3, 2012 | 12:23 PM
kejobe's Avatar
kejobe
If the cooler has been replaced, it is possable the check valve has been removed. If so, the fluid can drain out of the torque converter. If that happens, it needs to fill before the truck will move.
I removed the check valve on mine and have the same problem. I just shift to neutral for a few seconds before going into any other gear. The pumps in these trannies do not pump in park.
Old May 3, 2012 | 12:52 PM
ramitt360's Avatar
ramitt360
ahh good to know, thanks
Old May 3, 2012 | 12:56 PM
zman17's Avatar
zman17
Where is the tranny cooler and does it have the OEM cooler also? Post a pic.
