tranny fluid change, what a nice surprise.
Old May 3, 2012 | 11:04 AM
ramitt360's Avatar
ramitt360
Default tranny fluid change, what a nice surprise.
Well i am long over due for a fluid change to my shame when i dropped the pan i found all kinds of sluge which i expected. Dodge however was so kind to equip me with an extra bolt, incase I lose one. I was wondering what that pinging noise was for the past month.
Attached Thumbnails tranny fluid change, what a nice surprise.-2012-05-03-10.44.38.jpg
Old May 3, 2012 | 11:11 AM
zman17's Avatar
zman17
Retired Moderator - RIP
That bolt looks like one from the VB. Make sure none are missing.
Old May 3, 2012 | 11:14 AM
ramitt360's Avatar
ramitt360
I was hoping someone would know what that goes to. This is my first tranny fluid change..
Old May 3, 2012 | 11:20 AM
zman17's Avatar
zman17
Could be from elsewhere, Like the VB itself. Just look for any empty holes. but this pic might help.
Old May 3, 2012 | 11:29 AM
billcart's Avatar
billcart
Wow that looks terrible. Hows did it drive before you dropped the pan?
Old May 3, 2012 | 11:41 AM
zman17's Avatar
zman17
It's not that bad if it never has been changed before.
On a side note, I'd pull the Gov solenoid and clean it. And also, only use ATF+4 when you refill it. A band adjustment done correctly would also not hurt.
Old May 3, 2012 | 11:43 AM
ramitt360's Avatar
ramitt360
Yeah zman its one of those. The only problems i have with it is the first startup of the day. When i put it in gear, it takes about 2 or 3 seconds before it moves. Other than that, if i put the pedal to the floor it wont shift up til i let off the gas a little. That doesnt happen all the time though, once in a while. Other than those 2 things it chugs along just fine.
Old May 3, 2012 | 11:44 AM
ramitt360's Avatar
ramitt360
I dont remember what gears that shifting problem is, I mostly drive like a grampa
Old May 3, 2012 | 11:48 AM
zman17's Avatar
zman17
I'd would clean or replace the Gov solenoid and adjust bands if I were you. Replace with one of these. You don't have to get it there, you can call around to local tranny shops and see if they have them.
http://www.doghousediesel.com/catalog/i307.html
ramitt360's Avatar
ramitt360
I bought the truck at 89k miles and it has 106 right now. I'm almost positive he had tranny work done and he did have a good size cooler put on.
