02 sensor question
Old May 20, 2012 | 12:14 PM
mccart's Avatar
mccart
Default 02 sensor question
I heard that you can get a resistor from radio shack and put it between the 02 sensors and not have them in the exhaust, and it will run at the factory air/fuel mixture setting.
Is this true?
Old May 20, 2012 | 12:22 PM
No. The resistor would give the PCM a fixed value for the return signal, and would set a code.
Why would you not want your O2 sensor in the exhaust? I could see doing the non-fouler trick on the post-cat O2, if your cat is hollow.... but, the pre-cat O2 sensor plays an important role in the efficiency of your engine. You WANT that feller in place, and doing his job properly.
Old May 20, 2012 | 12:28 PM
mccart's Avatar
mccart
I was going to run dual straight pipes and was wondering if it would work. What's the non fouler trick?
Old May 20, 2012 | 01:00 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Which o2 are you talking about? The pre cat needs nothing. And here's the non fouler trick, that can be found in the FAQ/DIY section, along with a lot of other great info. I suggest you look through it.
https://dodgeforum.com/forum/2nd-gen...converter.html
Old May 20, 2012 | 01:23 PM
dlyter09's Avatar
dlyter09
The non fouler will work and is much cheaper than a simulator. Check out the link zman posted. It will explain it all
Old May 20, 2012 | 06:55 PM
mccart's Avatar
mccart
Will it still work with 2 pipes?
Old May 20, 2012 | 06:57 PM
stewie01's Avatar
stewie01
Should. Just need it in 1 pipe.
Wouldn't having one in each pipe throw off the readings?
Old May 20, 2012 | 07:00 PM
dlyter09's Avatar
dlyter09
Yea it will work for 2 as long as its post cat like stated before. You don't wanna mess with pre cat
