Thats why the limited slip doesn't work anymore
Old Jun 13, 2012 | 06:46 PM
  #41
jgreen2217's Avatar
jgreen2217
replacing 3:55 gears with 4:56 gears and was woundering if i should leave the guts alone if everything is good or should i install a detriot trutrac, it will have 37/14/18 nitto terra graphlers and its a daily driver and towing everyonce and again
Old Jun 13, 2012 | 06:48 PM
  #42
Originally Posted by jgreen2217
i am regearing my truck to 4:56 within the next week or two and was woundering if it would be a good idea to put a detriot trutrac in while im in there ur just stick with stock guts if everything is all good
Need some info about your truck.... year/weight rating/etc....
If that is a 1500.... 35" is the largest recommended tire size. If you are 3/4 or 1 ton... those tires will be fine.
What do you have in the rear now? Open? Stock LSD? Other? Really, with either of the first two, if you are in there doing gears, NOW is the time to upgrade as well. Detroit Locker, or something equally as robust wouldn't be a bad plan.
Old Jun 13, 2012 | 07:57 PM
  #43
Wombat Ranger's Avatar
Wombat Ranger
If you are going to 37's, go with 4.88's.
Old Jun 13, 2012 | 08:23 PM
  #44
gdstock's Avatar
gdstock
that didnt ansewer my question at all
Ahhhh - chill, dude! That was to OP....before thread jack....
Old Jun 13, 2012 | 09:05 PM
  #45
99ram360sport's Avatar
99ram360sport
Gdstock, pictures will be coming of the old ring gear with missing teeth when I get back to the shop that installed them to take a picture.
I got to drive the truck today for awhile, I'm still being easy on the gears for the break in so no heavy throttle yet. But I can already tell I love the 4.10's it made the shifts better and has more power on take off. Our trucks really should off came with 4.10s from the factory.
Old Jun 13, 2012 | 09:20 PM
  #46
99ram360sport
Picture of the pieces found in my differential that let me know it was time for a rebuild:
http://s1267.photobucket.com/albums/...t=DSCN4053.jpg
Pictures of the new parts:
http://s1267.photobucket.com/albums/...t=DSCN4106.jpg
http://s1267.photobucket.com/albums/...t=DSCN4109.jpg
Old Jun 13, 2012 | 10:06 PM
  #47
dlyter09's Avatar
dlyter09
Its a mix of wanting more power and im planning on going to 35's
Old Jun 14, 2012 | 12:06 AM
  #48
gdstock's Avatar
gdstock
Any idea waht caused those chunks to come unglued? Faulty installation or misalignment on installation? Is the shop making it good (hopefully)?
One of the few things I have not done on a vehicle is the differential.
Old Jun 14, 2012 | 10:51 AM
  #49
Wombat Ranger
Why not just go to 4.88's? You will get more of a power increase, but still be comfortable on the freeway... You wouldn't wanna do it a third time would ya? Just keep in mind, 4.56's and 35's will only put you back to the stock powerband.
Old Jun 14, 2012 | 02:20 PM
  #50
99ram360sport
gdstock, the factory limited slip (trac-Lok) started to fall apart apparently a common problem. These parts floating around are what took the teeth off of the ring gear. You could actually see impact marks and fractures from where the limted slip clutch parts got caught between the ring gear and pinion on the broken tooth.
Picture of the ring gear as promised:
http://s1267.photobucket.com/albums/...t=DSCN4117.jpg
http://s1267.photobucket.com/albums/...t=DSCN4118.jpg
