Valve Timing Questions
Old Aug 12, 2012 | 03:52 PM
  #101
MeanMagnum99's Avatar
MeanMagnum99
Originally Posted by Hahns5.2
I have these in my truck and they get good reviews from others. I did have to have a valve job done on my clearwater heads for them.
http://www.ebay.com/itm/MOPAR-MAGNUM...item5ae8da093b
Well from Hughes I can get the stainless one piece valves for $11 each. What do y'all think?
Old Aug 12, 2012 | 03:57 PM
  #102
merc225hp's Avatar
merc225hp
I always pull up the 96 fsm I will switch over to the 2001 see if that helps you out. Page 1242 in the 2001 fsm
Old Aug 12, 2012 | 07:10 PM
  #103
MeanMagnum99
It looks as if I will be needing new valves, lifters, and a cam.
http://www.hughesengines.com/Index/p...=&partid=11430
This is the cam I'm looking at buying.
Old Aug 12, 2012 | 08:27 PM
  #104
aim4squirrels's Avatar
aim4squirrels
What size intake valves are you running on that 5.2L? If it's 2.02 valves, your p2v clearance is severely limited.
Depending on all the parts involved, that's probably too much cam for 1.7 roller rockers. You're liable to have issues.
If you want to read my pain, go over to bionic dodge and read a thread called "cam swap, advice appreciated" then, "cam swap part 2" and finally, "cam swap part 3" to find out what I went through with an odd cam/intake valve combo. You've got to degree in whatever cam you choose, you don't have much wiggle room with the flat topped pistons.
Old Aug 12, 2012 | 08:53 PM
  #105
MeanMagnum99
I have the stock valves 1.92/1.62. So you think I should just go with a stock replacement cam? I'm not looking for big power. I just want my truck back and running at this point lol
Old Aug 12, 2012 | 10:18 PM
  #106
aim4squirrels
I would go with a RV cam and get the most torque you can from it. Let whomever you purchase it from know that you have 1.7 rockers and they can get a custom grind to make it work.
Old Aug 12, 2012 | 11:06 PM
  #107
MeanMagnum99
Where do you recommend I get one from? Or at least a good stock cam. I got another engine I'm planning on building for this truck (built 408) and just need it to be streetablr and nothing fancy or over the top.
Old Aug 12, 2012 | 11:12 PM
  #108
Hahns5.2's Avatar
Hahns5.2
I don't see how the stock cam could be damaged by this?
Old Aug 12, 2012 | 11:16 PM
  #109
MeanMagnum99
Will these work with my stock heads that I have now?
Old Aug 12, 2012 | 11:17 PM
  #110
MeanMagnum99
My cam I have now has 2 lobes that are in pretty bad shape. If I can just get a stock 5.2 magnum cam for a 99 I wouldn't complain.
