Engine and Plenum fixes...
Old Aug 31, 2012 | 04:00 PM
  #61
OK_Ram's Avatar
OK_Ram
Be very careful when you drill your pilot hole. Try using a nice punch to get a good center mark on that stud. The last thing you want is to get off center and allow that easy out to hit the actual head or block. If that happens it will be time to let a machine shop get it out and pay the pros.
Old Aug 31, 2012 | 04:01 PM
  #62
Good Advice here.
Old Aug 31, 2012 | 04:09 PM
  #63
InfO's Avatar
InfO
I read up on it, gonna head to CT once the GF gets home and I have access to a vehicle. Wish I lived closer to most of y'all
Thanks for all the help with a lot of this, and the praise. It's a learning process as I go. Would love to get a few things bolted back ONTO the truck before I go. I took a lot of pictures, but still prefer fresh in my mind
I'm going to pick up a torch and a few other things, then set to work on it.
Old Aug 31, 2012 | 08:15 PM
  #64
InfO's Avatar
InfO
SUCCESS!!!! It took some time, it was dark, and I had the GF holding the trouble light, but with a torch, vice grips, hammer, and air hammer (and some minor cursing...) I was able to get out both of the front bolts without having the drill. Very happy with the progress. Tapped the two holes (did the rest earlier, and the holes for the timing chain cover) and called it a night!
InfO.
Old Aug 31, 2012 | 08:32 PM
  #65
merc225hp's Avatar
merc225hp
Good for you man!
Old Sep 1, 2012 | 09:24 AM
  #66
InfO's Avatar
InfO
These were the two bastards that were slowing me down:
Picked up THIS today:
Also received my ignition wires and spark plugs. Stoked.
InfO.
Old Sep 1, 2012 | 03:59 PM
  #67
InfO's Avatar
InfO
Need feedback...
Did I just pooch this? Was putting in the new rear main seal. It came with a little tab of paper that was working great until the end when it ripped. I pushed in hard to try and limit contact with the sharp edge, but when I was finished was left with this:
(Put by the old seal for reference sake)
InfO.
Old Sep 1, 2012 | 04:11 PM
  #68
gdstock's Avatar
gdstock
OK. I see the seal, and I see the sliver of something.....what is the sliver from?
Old Sep 1, 2012 | 04:12 PM
  #69
InfO's Avatar
InfO
I'm just going to assume yes. Unfortunate, as I wanted to button up the bottom and even some of the rest of it before leaving to train in Florida for 2 weeks. Hopefully I remember where everything goes upon return.
Going to pick up some of that storage oil/marine fogger someone wrote and spray the whole area in it.
InfO.
Old Sep 1, 2012 | 04:14 PM
  #70
InfO's Avatar
InfO
From the new seal I put in. Looks like it shaved. Was hard to put in, so had to tap it. I had loosened the two previous caps as well and it was still a bit tight. Had help in pushing against the crank so it shouldn't have shaved, but it did. **** happens.
InfO.
