now power high oil presure
09-05-2012, 07:45 PM
on
It has now power like its not firing all cylinders but starts fine it has high oil pressure and sounds like something is rattling around in the motor
09-05-2012, 07:52 PM
Dodge Forum Administrator
That's not good...... getting any codes? (cylinder misfire chiefly....) Might not hurt to check the plugs, and do a compression test.
09-05-2012, 07:59 PM
on
Noo codes to check. Ran fine to work *** soon as I got off work ****.
09-05-2012, 08:19 PM
on
Its firing all cylinders but its like its being ckoked... exhaust valve stuck?
09-05-2012, 08:21 PM
Stuck valve would give a miss. Clogged cat?
09-05-2012, 08:32 PM
on
Its got that rattling around though. It will rev in neutral but in gear it just dies like its getting choked out. It is running kinda hot
09-05-2012, 09:14 PM
in order to check clogged cat, un screw the o2 sensor after the cat, see if it runs fine then, if it does then its the cat.
09-05-2012, 09:16 PM
on
^ thanks ill give it a try. If not looks like ill have to take it too an effing garage
09-06-2012, 09:54 AM
You want to remove the O2 in FRONT of the cat.
09-06-2012, 11:47 AM
on
I'm thinking its the cat... 110 thousand on the orig
