TTY Torque To Yield Bolts
Old 09-14-2012, 01:15 PM
It's Me Patt's Avatar
It's Me Patt
It's Me Patt is offline
Default TTY Torque To Yield Bolts
I must say to start, my service manual doesn't mention anything anywhere about not reusing IM bolts or any other that I've come across..With that said TTY bolts are: Bolts that are torqued to spec..But some bolts that are torqued to spec such as IM or plenum pan bolts that are torqued in a three step sequence 'should not' be reused..When torqued to spec in a single step it's referred to as 'Elastic deformation' and when torqued in a multi step sequence it's referred to as 'Plastic deformation'..the 2nd type is when the bolt has changed shape and or length..As a result they 'should' not be reused...
Old 09-14-2012, 01:18 PM
Gary-L's Avatar
Gary-L
Gary-L is offline
Old 09-14-2012, 06:25 PM
Adobedude's Avatar
Adobedude
Adobedude is offline
The 3 step torque process on the intake mainifold is to get it to seal to the heads properly.
Old 09-14-2012, 06:43 PM
It's Me Patt
Yup, just like using the star pattern when tightening lug nuts! Seat it evenly eh...
Old 09-14-2012, 07:08 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,395 Likes on 3,135 Posts
Yeah, its been an ongoing debate whether the intake bolts are TTY, re-useable or what.... for my part... when I had them off, they were cheap, low grade bolts, of which, two broke off when pulling the intake. I replaced them. While it may not be absolutely necessary...... it strikes me as 'just a good idea', given the (lack of) quality of the bolts. Replacing them with some good grade 5 fasteners, or better..... would more than likely solve the issue permanently.
Old 09-14-2012, 08:45 PM
Adobedude's Avatar
Adobedude
I've used SS button tops from day one with a little anti sieze, used them with 3 different manifolds on 4 different heads...Never had a problem.
But yeah, the stock bolts are junk....And how can anything be TTY with 12 ft lbs of torque anyway?
Old 09-14-2012, 08:47 PM
Adobedude's Avatar
Adobedude
And valve covers, diff covers, plenum plates and cylinder heads etc etc...Start from the center and work your way out, rinse repeat.
Old 09-14-2012, 09:00 PM
It's Me Patt
True, true..not to mention a new set came with my hughes kit Silly Q, what's better grade 5 or 8?
Old 09-14-2012, 09:20 PM
Vegas360's Avatar
Vegas360
Vegas360 is offline
Grade 5 will expand, bend, and contract with the motors heat. Grade 8 are more brittle but stronger. When they break they just snap not bend. Use the right bolts for the right job!
Old 09-14-2012, 09:58 PM
It's Me Patt
Wonder why that's what the dealership sells & why hughes sent me grade 8's then..I got duped man!
Quick Reply: TTY Torque To Yield Bolts
