Transmission's acting funny,
#51
Flushing the debris from the TC into the rest of the trans will not fix anything. And thickening the fluid will not produce a positive outcome. Unlike motor oil, the function of the trans fluid is not improved by viscosity enhancement. It is the difference between lubrication and hydraulics. Just saying.....
#53
#54
Also in the fluid in general.. will look like sawdust.. or gold dust.. kinda floating around. Don't be surprised if you find grey gunk on the mag or bottom of the pan.
As far as the power flush.. I'm not talking about a Jiffy Lube Special rather a real service to the Transmission by a reputable transmission shop.. draining the tranny wont get out what's in the Torque converter nor the lines nor the cooler in the front of the truck. Esp. if something is clogged up.
#56
Trouble is, a flush breaks loose all that crap, but, doesn't always (rarely) get it all out of the system.... and the debris drifting about loose tends to clog/jam valves, and the trans quits working. If the trans hasn't been flushed regularly all of its life, doing so is a big gamble..... If you really want to change out the fluid, do a trans service (fluid and filter), install a drain plug, and once a week or so, pull the plug, drain the fluid, and replace with fresh.
#57
#58
#59
The question is how long before it starts again..and I believe when it does another fluid change is called for..aka the safe flush method..I'll be posting a shudder update soon! glad to hear it's gone tho..
#60
Okay, will the safe flush method be in that post? and what will I need to get for It so I know what to buy?Working on getting my muffler off and checking the cat. The brackets are real rusty it's goin to be a while.
On another note I'm not loosing oil like I have been. Should I be concerned?lol. However my antifreeze leak isn't so bad now Either? could they be connected with the shudder problem? somethings over heating?
