need help with timing a rebuilt 318
The cost has nothing to do w/time it's for use of their equipment, computer, scanners, etc. But depends where you bring it approx $150
Have it checked somewhere else just in case. If you get the same result, gram the FSM and check voltage on pins per manual. Maybe just one conductor issue and may be easy to fix.
You don't live anywhere close to HERE do you?
Here is some timing info. http://www.bionicdodge.com/Download/...uel%20Sync.pdf
http://www.moparchat.com/forums/showthread.php?t=96310
ok so now its running no back fire turn the cap also found out i had two busted injetors on the rail fixed that an turn the cap but now my problem is it still feels like it lacking some power an now the oil pressure gauge will go to 0 then come back up then go back down, what could be causing this to happen
