4wheel drive kicks when turning left
Old Dec 30, 2012 | 12:05 AM
Smalls3521's Avatar
Smalls3521
Default 4wheel drive kicks when turning left
In 2 wheel drive steers fine but when I lock in 4 wheel drive it kicks the steering. Any help would be awesome.
Old Dec 30, 2012 | 12:58 AM
jasonw's Avatar
jasonw
Site Moderator
For future reference:
https://dodgeforum.com/forum/dodge-r...s-section.html
What model year truck/trim level/options/etc. do you have?
Old Dec 30, 2012 | 12:32 PM
Smalls3521's Avatar
Smalls3521
1999 1500 ext cab. I also have a grinding noise coming from the front end. I just emptied, cleaned and refilled the diff.
Old Dec 30, 2012 | 02:26 PM
cyclone429's Avatar
cyclone429
When in 4 wheel drive, all four wheels drive equal, if thiers no noise in a stright line, you have no issues.
When your turn left, the outer wheels kick because the inner wheels have less distance to travel, where as the outer wheels have to travel a greater distance, and with all four wheels being driven = this causes the kicking..
When wheels have no traction, than you will not get the kicking action when in 4wd, as all four wheels are not rotating =
most 4wd are really only 3wd unless you run a locker in the front diff..
Old Dec 30, 2012 | 07:49 PM
Close. Most 4wd are really 2wd, unless you have lockers front AND rear.
Old Dec 30, 2012 | 08:06 PM
gdstock's Avatar
gdstock
Are you new to 4wd? As mentioned, what you are experiencing is normal. Do not drive in 4wd on dry pavement, and easy in sharp turns. Tears heck out of tires as well.
Old Dec 30, 2012 | 08:15 PM
stewie01's Avatar
stewie01
It's almost sad the difference that ONE tire spinning up front does...
Old Dec 30, 2012 | 08:36 PM
Smalls3521's Avatar
Smalls3521
I am not new to 4 wheel drive, I know how to drive with 4 wheel. The unusual noise happens only when I lock into 4 wheel. It makes the sound like putting a card in the spokes of a bicycle. It happens when turning and going straight.
Old Dec 30, 2012 | 08:47 PM
gdstock's Avatar
gdstock
Hey, no offense intended. lots of new guys come here that have no 4wd experience and think something is wrong. Since there was no indication that you have 4wd experience, it was a legitimate question for clarity.
OK. now about the card in the spokes sound - That's different from what I understood in original post. Check ujoints on front axle and hub bearings.
Old Dec 30, 2012 | 08:55 PM
UnregisteredUser's Avatar
UnregisteredUser
Someone please move the cited article to the WTF section because this guy doesn't know WTF he's talking about.
