Tranny problems even after replacement...need help
Old 01-29-2013 | 02:51 PM
lovettoride's Avatar
lovettoride
Well so far i think i got it fixed, ive driven about 150 miles but it has sliped twice but i think thats just the connection. I now have another problem, my 4wd wont engage it gos into 4 hi and 4 low but only has 2wd. What could it be?
  #32
Old 01-29-2013 | 02:53 PM
dlyter09's Avatar
dlyter09
Check the cad..
  #33
Old 01-29-2013 | 05:06 PM
lovettoride
Whats the cad?
  #34
Old 01-29-2013 | 05:09 PM
Central axle disconnect. It's on the passenger side of the front axle. Vacuum controlled from a switch on the t-case.
  #35
Old 01-29-2013 | 09:05 PM
lovettoride
Shold i check the switch itself or the vacuum lines? And does anyone have a routing diagram for the vacuum lines?
  #36
Old 01-30-2013 | 08:04 AM
petea216's Avatar
petea216
Mine had a leak in the rubber vacuum manifold that presses onto the switch on the T-Case. While running, in 2wd, pull the hoses (ONE AT A TIME) at the CAD. Feel for vacuum on one hoses. Put it into 4x4 now. Check again, there should be vacuum to the other hose now. of not, you either have a vacuum leak at one of the hoses, switch or the switch itself is bad. If you don't get vacuum at all, there's a vacuum leak leading up to the switch from the back of the engine.
  #37
Old 02-06-2013 | 10:43 AM
lovettoride
Well i havent got a chance to look at the vac lines but my trany and a new problem once i shift into o/d it shutters really bad, but only in o/d if i shut o/d off it works fine.
And suggestion's?
  #38
Old 02-06-2013 | 11:12 AM
Engine miss. When's the last time you looked at plugs/wires/cap/rotor? Fixed the plenum??
  #39
Old 02-06-2013 | 01:08 PM
lovettoride
I havent with this truck, but i did just get the heater core flushed todY maybe the guy wiggled something loose
  #40
Old 02-07-2013 | 01:52 AM
lovettoride
If it was an engine miss wouldent it do it in other gears also?
Quick Reply: Tranny problems even after replacement...need help
