Tranny problems even after replacement...need help
Old 01-21-2013 | 01:40 PM
redneck_ram's Avatar
redneck_ram
Originally Posted by lovettoride
I cant find the service manual, but just to cover the bases if its not the tv cable what else could it be?
its gotta be electrical. could be a dirty connection, somewhere. or the vehicle side of the harness is grounding out somewhere.
Old 01-21-2013 | 03:38 PM
Arde's Avatar
Arde
FSM
https://dodgeforum.com/forum/2nd-gen...e-manuals.html
Old 01-21-2013 | 05:14 PM
lovettoride's Avatar
lovettoride
So would i need the 97 or the 01 manual?
Old 01-21-2013 | 08:36 PM
Possible output speed sensor, PCM, etc. Does the speedo do strange things when the trans misbehaves?
Old 01-21-2013 | 09:08 PM
lovettoride
Speedo hasent done anything that ive notice
Old 01-21-2013 | 09:39 PM
gdstock's Avatar
gdstock
I don't know.....
If you put your vehicle info in your signature we could answer that question. Just makes it easier for us...
Old 01-22-2013 | 02:23 AM
lovettoride
I think i got it hope it helps
Old 01-22-2013 | 10:49 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Since you've got a 99, you can do the key trick.
Do what heyyou said, on/off three times, third time you keep it on.
Something should start blinking and the odo window will start flashing codes at you.
Old 01-22-2013 | 10:51 AM
dlyter09's Avatar
dlyter09
Your gonna be killing that trans if you dont soon regear your axles.. Key trick will work for your 99... Try it and see what you get
Old 01-22-2013 | 05:37 PM
lovettoride
Ive tried the key trick a few time and havent got it tow work but ill try agaun when i get home, and i planned on regearing once i get the money, and i was also talkig to a guy about it at work today and he said it sounded like the torque converter, what do u guys think about that?
Quick Reply: Tranny problems even after replacement...need help
