Am I knuts?
Old Jan 22, 2013 | 09:59 PM
  #31
Originally Posted by MHell2k13
HAha so you live on a farm?
Back in the day it was a farm, and I am still surrounded by farmland. (which is why I like this place to begin with..... just moved in in november. )
Old Jan 22, 2013 | 11:17 PM
  #32
MHell2k13's Avatar
MHell2k13
Yeah I'm on a functioning pig farm.. That's what my truck hauls whn the cummins is in for work
Old Jan 22, 2013 | 11:39 PM
  #33
merc225hp's Avatar
merc225hp
Good looking truck the man, needs a little lift kit.
Old Jan 22, 2013 | 11:56 PM
  #34
MHell2k13's Avatar
MHell2k13
Yeah haha I wanted to do a 3 inch leveling kit because my rearend Is soooo high lol. That is higher on the list before a suspension lift. I felt the pain of no leveling kit when we were gf through a dry channel in a field with a hay rack and I almost bottomed out on some boulders in the front. But my rear is pretty good.
Old Jan 23, 2013 | 12:19 AM
  #35
gdstock's Avatar
gdstock
figured i would throw in a picture
This pic could be my back yard.....
Too much snow and about 100 too few deer to be my back yard....heehee....
+1 on Merc's suggestion to check compression. you don't want to pile a lot of time and money into an engine that is not long for the road.
If it tests good, you may want to consider adding a new double roller timing set when doing the intake (plenum). Another add that will make a difference in HS 1.7 rockers. Costs about what facny valve covers will cost, but offers more performance value.
Old Jan 23, 2013 | 12:24 AM
  #36
merc225hp's Avatar
merc225hp
Good point I forgot about that, thank you.
Old Jan 23, 2013 | 07:04 AM
  #37
Truedge's Avatar
Truedge
I haven't seen if anybody suggested you do this yet.. https://dodgeforum.com/forum/2nd-gen...46rh-46re.html
That'll help you keep that transmission going
Old Jan 23, 2013 | 11:59 PM
  #38
MHell2k13's Avatar
MHell2k13
Thanks for that tip I will look into that. Seems very logical. I will add it to my list of to do
Old Jan 25, 2013 | 02:54 AM
  #39
JoshSlash87's Avatar
JoshSlash87
Hey if you need help I'm in Wausau ;-) Would love to help another forum member out!.
Old Jan 25, 2013 | 03:07 AM
  #40
JoshSlash87
Save that CAI money for better thing's they do little for mpg and hp. 16 mpg will be at the very best high end of things, don't expect much more than that. I am not one for using a tuner on a 96, yes some do but not me. I would hunt down a Mopar performance pcm
# P5249935 it's what I use and I would use nothing else on a 96. Gears would help a little chances are you have 3.55 going to a 3.92 would help. What size tire's do you have on this beast?
With stock tires 3.55's are best for mileage unless you have bigger tires,then you might need 3.92s just to have the power to get going. 3.92's with stock tires will turn more engine RPM to do the same amount of work thus reducing mileage.
My brothers '69 Camaro with 3.08's would turn 140mph like nobodies business at 6,000 Rpm then he swapped in 4.11's and it would only do 126mph at 6,000Rpm but it got there VERY quick lol. Your fuel efficency really goes down unless you make up for the gear ratio with your tire size, which in that effect puts you back at square one. 3.55's are plenty good for a Ram with stock size tires.
