Did something stupid: hurt driveline?
Old Jan 29, 2013 | 11:00 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
The drives go left to right on the 98 and up trucks
PRND....
Old Jan 29, 2013 | 11:19 AM
Have a look under there, and see if anything is obvious, may have broke a mount or some such.
Old Jan 29, 2013 | 11:45 AM
dlyter09's Avatar
dlyter09
I did it on my 92 before.. Nothing ever came of it.. I was coasting down a hill and forgot I already put it in neutral.. Pushed it up into reverse and it just shut off.. I threw it back into neutral and coasted to a stop.. Everything was good for a year or 2 until I blew the trans apart.... You can also check the snap ring on the tcase on top of everything else already mentioned.
Old Jan 29, 2013 | 11:53 AM
kejobe's Avatar
kejobe
Did the same thing in my old car. It was wanting to stall out so I went to put into neutral to try and get it to smooth out. At the same time I went to neutral I hit the gas. Well, that happened right as I hit a bump so it jerked my hand and I ended up hitting reverse just as I hit the gas. Was doing about 50-55mph. It gave a squeel from the tires (was rear wheel drive) then stalled. Luckely no damage.
Anyway, Id take a look for a bad ujoint or something obvious before dropping the pan.
Old Jan 30, 2013 | 09:29 AM
dodge dude94
Hadn't thought of mounts. I will check!
I dread the snap ring failure. lol
What did the trans do? Or what were you doing?
I am going to look at the ujoints when the weather is a bit more stable. Freaking windy outside. lol
Thanks for the advice guys, I will keep an eye on all this. Strangely, the steering gear hasn't leaked anymore. I drove it several times yesterday and it's still wet, but the level hasn't dropped. Weird.
Old Jan 30, 2013 | 09:34 AM
stewie01's Avatar
stewie01
MythBuster's did this test years back, with an automatic and a manual transmission, they couldn't grenade either transmission...
Old Jan 30, 2013 | 10:22 AM
dodge dude94
Dude, they weren't trying to grenade the trans, there were trying to get the u-joints to snap and flip the car over.
But since they were using a Plymouth, they had to modify the u-joints to break.
Old Jan 30, 2013 | 10:25 AM
h3lzsn1p3r's Avatar
h3lzsn1p3r
i have done it aslong as you still have reverse you sould not have hurt anything
look at the ds support bearing (if equiped)
Old Jan 30, 2013 | 10:29 AM
dodge dude94
I do still have reverse, and no slippage minus the cold slip is has because of fluid.
No support bearing.
The thing that bothers me is the thunk I feel at about 25 mph when letting of the gas...
Old Jan 30, 2013 | 10:30 AM
petea216's Avatar
petea216
Originally Posted by cruzer55
Excuse Me for interrupting,isn't reverse up from neutral and not down? Correct me if I'm wrong.Just a thought...
Just a guess, but I'm gonna say the shifter was accidently pushed a lil past neutral just enough to engage the reverse gear.
