Overdrive bucking/shake. Missfire?
Old Apr 17, 2013 | 06:27 AM
  #31
olred1998's Avatar
olred1998
right now I'm working on the exhaust, cat, and o2s. as soon as I can ill do a compression test and updates.
Old May 24, 2013 | 03:58 PM
  #32
olred1998's Avatar
olred1998
ok well its been a while but finally did a compression check
number 1-8 cyclinders 130,155,145,155,145,155,155,100
pit some oil in the #1 and 8 cylinder and got 10psi higher
truck finally threw a code for #8. what gets me is the truck only has 85xxx.
Old Nov 11, 2017 | 12:13 PM
  #33
Burdman69's Avatar
Burdman69
What was the fix for this? Were the heads ok? My 2006 4.7 is doing the same thing with misfire on 1 and 5 plus a random one.
Old Nov 11, 2017 | 06:49 PM
  #34
Completely different engine. You want to be in the third gen ram section.
Old Nov 13, 2017 | 08:19 AM
  #35
Burdman69's Avatar
Burdman69
I know but internals all work on the same principals. So that's why I asked.
Old Nov 13, 2017 | 10:15 AM
  #36
Even the internals are different. The only things the engines have in common, is they are both internal combustion engines. NOTHING else is the same. Not the valve train, not the electronics, nothing. You want to post in the correct section, where folks with the SAME motor might actually be able to help you.
