Think I have a small coolant leak-do you trust any of those sealants?
Hi all,
I have a 1994 5.2 1500 with 140k miles. I bought it a year and a half ago from an older guy who only sporadically dove it the last 5-6 years. I drive it mostly on weekends or to work when my car is down.
Couple months ago I noticed a chocolate milk foam on the dipstick and a little foam floating in the coolant at the top of the radiator. I drained the oil and it looked fine. The truck runs good. I'm guessing I've probably got a small head gasket leak?
I really don't have the money to pay to have it fixed nor the space to do it myself. I have seen things to put in your radiator to seal leaks. Anyone use these and do they work? Am I screwed or can I get some more mileage out of this engine before I have to have it gone over or replaced?
Thanks.
Thanks.
i'll go the other way...
lots of chocolate milk/brown crap in the oil would be coolant mixing in from a head gasket or intake gasket or cracked head. however - a small amount at the top of the dipstick on an infrequently driven car might be condensation.
i'd change the oil and watch it. when you do drive it - try to drive it enough that it gets up to operating temp and stays there long enough to evaporate off any condensation. also drain/flush the coolant. there are 2 block drain plugs hiding behind the engine mounts.
just for a good evaluation of the engine - you can rent a compression tester at your local parts store and check for major problems. a coolant leak and a compression leak sometimes go together, but be aware that they can also be completely separate.
if you determine that it is a head gasket leak, you can try a head gasket sealer. its a liquid glass type stuff you pour in the radiator and it seals up high temperature leaks. sometimes it works. if it doesn't - you're only out a few bucks and you're not any worse off than your were.
http://shop.advanceautoparts.com/web...sket+stop+leak
A friend of mine used this stuff on a head gasket leak and said it actually worked.
http://shop.advanceautoparts.com/web...vil#fragment-3
I have no first hand experience with it and would be skeptical myself but he used it a few years ago and is still driving his truck. I've used other products made by the same company before and had good luck with them. I think they have a $ back guarantee on it also.
Trending Topics
Boy dhvaughan I hope you're right. Just drove it 200 miles today on a hunting trip and it ran fine. Had to top off the radiator before I left this morning but oil pressure and temps were good whole day. I'll see if I can get a pressure tester next weekend and see if there's any clue there.
