PLEASE HELP 2001 Ram 1500 5.2 stalling backfiring replaced alot still problems
Old May 22, 2013 | 05:56 PM
qspinnyj's Avatar
qspinnyj
coil is not replaced but it works if i can make it idle correctly, did not replace the cam sensor, did not remove or turn the distributor. usually buy napa parts, did not clean iac will do first thing in the morning and look into replacing cam sensor depending on price I have too much money in this truck already and quickly becoming broke. I will report everything I do in the morning and if it solved the problem ...Thanks
Old May 22, 2013 | 06:09 PM
qspinnyj's Avatar
qspinnyj
can not find the cam sensor for my trucK anywhere did you me crankshaft sensor?
Old May 22, 2013 | 07:07 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You said you replaced "pick up coil" I assume that the cam sensor is what you replaced. (it's under the distributor cap and rotor. Crank sensor is on passenger side , back of head on bell housing. Download the manual.
Old May 23, 2013 | 10:03 AM
qspinnyj's Avatar
qspinnyj
I did download the manual. Just replaced the TPS it raised my idle form 500 to 750 rpm otherwise no change iacv is clean and testing right
Old May 23, 2013 | 10:09 AM
Crank sensor.
Old May 23, 2013 | 12:03 PM
qspinnyj's Avatar
qspinnyj
what do you think about the map sensor?
Old May 23, 2013 | 03:34 PM
qspinnyj's Avatar
qspinnyj
map and crank sensors are replaced no change
Old May 23, 2013 | 03:57 PM
qspinnyj's Avatar
qspinnyj
Maybe this will help
Old May 24, 2013 | 02:59 PM
xjarhead69's Avatar
xjarhead69
Might check out proper routing of the sparkplug wires per this TSB
http://dodgeram.info/tsb/1998/18-48-98/18-48-98-v8.htm
Dave
Old May 24, 2013 | 03:17 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Sounds like an injector possibly sticking open. Or multiple.
