small air hose looks like it was cut. please read!!
Old Jul 3, 2013 | 08:30 AM
BrandonBuc'em's Avatar
BrandonBuc'em
Default small air hose looks like it was cut. please read!!
so i just put sea foam in my 97 1500. i drove it pretty hard for 10 miles, got back to my house popped the hood to listen for a smoother idle ect. i heard a "blowing air" sound. i found it, its on the passenger side, coming from the rear side of the block, from a splitter and through a gromet into the firewall. there is another small line coming up from under the weather striping and it looks like its been cut clean. i have no idea, i never noticed this before, its hard to think sea foam could cause a clean cut. i have pictures im going to upload when my internet stops acting up. thanks ahead of time.
Old Jul 3, 2013 | 08:35 AM
2 or 4wd? What color is the line? Is it green by any chance?
Old Jul 3, 2013 | 08:40 AM
BrandonBuc'em
here are some picturs, the first picture is the "splitter", second is the splitter and the maybe cut line, 3rd is the upper grommet where the cut line comes from, 4 is the lower gromet where the line which does connect to that splitter. any ideas?
Old Jul 3, 2013 | 08:42 AM
BrandonBuc'em
nope, not green. its black. the one end of the splitter was blowing air from it. i shut it down to look at it closer cause it was pretty hot. i ran her pretty hard. much harder then i usually do. thats what your supposed to do.
Old Jul 3, 2013 | 08:43 AM
BrandonBuc'em
oh, 4wd
Old Jul 3, 2013 | 09:26 AM
I think the one running thru the grommet goes to the vacuum reservoir under the cowl. The other line running in thru the a/c line should go to the HVAC control head. (most of the vents are vacuum operated.)
Do your vents work? Cruise? 4x4 engage properly?
Old Jul 3, 2013 | 10:41 AM
BrandonBuc'em
The only air setting that works is defog(blows at windshield and feet), 4x4 and cruise work fine. Should I just connect the two lines with some tape and call it done?
Old Jul 3, 2013 | 11:21 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Yep, that's a check valve. You might see if you can find a truck at the junkyard that has that intact and replace it.
Also, your heater core bypassed? lol
Old Jul 3, 2013 | 11:45 AM
Don't use tape.... just get a piece of rubber line with the right inside diameter. local parts store probably sells it by the foot.
Old Jul 3, 2013 | 12:50 PM
merc225hp's Avatar
merc225hp
Windshield washer line should fit, just cut an inch off it and use it to splice the vac line.
