Do you have this in your differential?
Old 12-16-2013, 05:28 PM
merc225hp's Avatar
merc225hp
merc225hp is offline
Not a problem.
It took me a bit to learn how drive it with the DL's and now it will take me a little bit to learn to get used to this way lol.
  #22
Old 12-16-2013, 06:37 PM
army_greywolf's Avatar
army_greywolf
army_greywolf is offline
My trak lock dropped right in...with zero adjustment needed, did yours? Wonder if that helps in the decision for the OP to ditch the lsd.
  #23
Old 12-16-2013, 06:47 PM
merc225hp's Avatar
merc225hp
Slapped the tone ring and ring gear on the new carrier (use new ring gear bolts), did a couple of lash adjustments tq'd it down and all was good. I still say the 9.25 is one of the easiest diff's to work on other than a third member diff. I think you like I have done this work before so might be easier for us.
  #24
Old 01-04-2014, 12:45 AM
jwalkanime's Avatar
jwalkanime
jwalkanime is offline
Not much of an update but I took a pic of my rear end two days after removing the clips because I found a flat washer in the bottom of the drip pan (oops). I don't disagree with Merc225 on the importance of the clips, I just found my truck works fine with-out, for the light duty I throw at it (for now).
https://www.dropbox.com/s/guy9eivduw...0%28HDR%29.jpg
  #25
Old 01-04-2014, 07:57 AM
army_greywolf
Far be it from me to get on ya about saving cash, if it works it works.
  #26
Old 03-02-2014, 05:15 PM
jwalkanime's Avatar
jwalkanime
Default update:(
So after a while of using my truck as my daily driver, I started to get a lil cocky on the performance of my rear axel. I did a lil bit of offroadn and broke the tires loose a few times but, a familiar vibration has returned. Long story short, I took the cover off to find a broken LSD disc (I think) at the bottom. it's an all metal piece and looks to be the same diameter as the other discs. anyway, i said id update ya and I have, back to work I go...
Long live merc225hp
  #27
Old 03-02-2014, 07:17 PM
HeyYou is online now
Dodge Forum Administrator
Received 3,391 Likes on 3,131 Posts
Time to rebuild the clutch packs?
Quick Reply: Do you have this in your differential?
