Trimming Required
Old Nov 19, 2013 | 12:27 PM
97r/tram's Avatar
97r/tram
I replied to your pm.
Might move the fronts outboard a bit. That *might* cause some clearance issues, but, yours is the first I have heard of with 5" lift that needed extensive trimming for 35" tires. Tell them not to worry about the trimming, and you will take care of it if it becomes necessary. Don't let them talk you into anything without actually seeing the tires ON the truck.
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
They're just hubs. I don't see how they would affect how the tires are placed in the wheel wells.
Old Nov 19, 2013 | 12:28 PM
Wheel mounting surface moves outboard a bit. I think.
Old Nov 19, 2013 | 12:34 PM
merc225hp's Avatar
merc225hp
Originally Posted by 97r/tram
I ran 5 inch backspacing on 315/75/16s on 5 inches of lift. no problems.
Irrelevant to his problem, note he is using 16x10 rims not a 16x8. With the 4" bs this will put his wheels out farther than what you had. This might cause him some issues, but I also ran the same spec rims/size tire and never had a issue.
Just because you say you can run a 35's with a level kit does not mean it's right. There was no way in hades that I would have fit a 35 with just a level kit.
InfO's Avatar
InfO
So I'm on my phone now. Work computer decided to reboot during all of this.
Can't see the instructions and I didn't see anything on the webpage mentioning that the mounting surface moves outwards. They do state the center bore is larger, seems odd they wouldn't mention anything else.
They will eventually have to take the truck out to make sure the gears are good... There is no way they've even put the tires on yet and the guy that called didn't say "this is because of your hub conversion" which makes me wonder if they are going off pre conceived notions over visually seeing it.
I'm waiting on a call back, but am definitely leaning towards saying no. If no one here thinks there needs to be trimming, odds are the shop won't know better. Not saying they are wrong, but not sure how many 2nd gen rams they see.
Old Nov 19, 2013 | 12:35 PM
merc225hp's Avatar
merc225hp
From what I see about a 1/2 inch thats it.
Old Nov 19, 2013 | 12:36 PM
Don't give them the go-ahead for trimming until YOU see the truck.
Old Nov 19, 2013 | 12:44 PM
merc225hp's Avatar
merc225hp
^^^ He is not letting them cut anything all until he see's it.
Posting for Info
Anybody know if the 99 sport bumper has a different wheel well opening size? From the reg bumper trucks.
Old Nov 19, 2013 | 12:54 PM
Ham Bone's Avatar
Ham Bone
sports bumpers are the same just painted as far as I know
