Top removal thread
Old Nov 24, 2013 | 02:32 PM
  #61
merc225hp's Avatar
merc225hp
One box will be cheaper than one from here and one from Wildman, thats what I would do.
Hey You has posted a nice list for upgrades.
Valve covers can be seen in the lower left of the pix
A pix of just a few of my spares that I am selling or giving away.
Old Nov 24, 2013 | 02:33 PM
  #62
Depending on your cam choice, Roller rockers sure wouldn't hurt you. Make sure the folks you talk to about the cam know what ratio rockers you are going with though. Just switching to 1.7 ratio Harland Sharp rollers is a nice performance boost, but, if you change the cam, sticking with the stock 1.6 ratio would be best.
Roller rockers reduce friction, so, you have a bit more power, and things don't wear out as quickly. Win on both counts.
if you elect to change the cam, make sure your heads will support the lift the cam provides, with your rockers of choice. Stock heads can only do about .480 lift. You can order your heads with different valve springs, that will tolerate more, for probably just a few bucks more from Clearwater/Odessa.
Old Nov 24, 2013 | 05:23 PM
  #63
Wildman4x4nut's Avatar
Wildman4x4nut
Veteran: Army
Stallion,
I will get a box together with the valve covers & fuel rail. Let me know if there is anything else you need. I can send my rocker arms if you need them too. Or if you want them for just in case that is fine too.
True that. You get to play guinea pig for us?
HeyYou,
Yep I guess I will be the guinea pig for everyone.
Old Nov 24, 2013 | 06:40 PM
  #64
stallion81's Avatar
stallion81
Thanks Wild.....Clearwater is supposed to send an extra set of rockers/pushrods if they have them...mine looked good by eye. I think the fuel rail and VC's get me close...Just need the alum plenum. I can find the sensors....
Hey you......gotta sell some of that cream....... DR cream by HY......Nobody knows what its for.....but thats why they buy it.... as for sound....get me the best fuel mileage and Ill like the sound =). Otherwise it better lift my wifes skirt......
Old Dec 2, 2013 | 04:37 PM
  #65
stallion81's Avatar
stallion81
Hey Wildman..... I sent a PM. I need a fuel rail and valve covers.....LMK ASAP as I need to find some if you dont come through. Thanks for your time.
Old Dec 2, 2013 | 05:39 PM
  #66
Where ya at?
Old Dec 3, 2013 | 06:10 PM
  #67
stallion81's Avatar
stallion81
All good, I said screw it and ordered the black wrinkles(mopar). Used fuel rail coming also(loaded), mine was rusted to hell, and was no good. I've got everything here or coming by the 9th, except haven't decided on new injectors or just clean & rebuild the old ones(16 to choose from). Gotta get a muffler also. I went with the flowmaster CAT direct fit...to make it easy and road ready. Its got a cherry bomb on it now with a 45 downturn. Not sure if I can reuse it though. Quick cheap muffler for it? CAT is 2.5" out.
Should be back on the road in 2 weeks or less. My engine guy is a bit behind.....but he's back on track now. EXH manifolds, timing cover, INT manifold all blasted and painted/clearcoat. Block will be at machine shop tomorrow. Hes gonna hit the frame in the engine compartment also(best he can).
Should I look into the INT manifold mod? He's gonna hog out the exhaust mans at the shop. I also have the 50mm TB coming. Links to manifold mod?
Thanks again......
Old Dec 4, 2013 | 10:01 AM
  #68
Wildman4x4nut
Veteran: Army
stallion sorry for not getting back to you sooner. I just sent you a PM.
Old Dec 4, 2013 | 10:03 AM
  #69
Gary-L's Avatar
Gary-L
Veteran: Navy
Thanks again......
As long as everything is apart, go ahead and cut the intake runners down and if there is a center divider plate take it out as well.
Old Dec 4, 2013 | 01:09 PM
  #70
I think the center divider went away in 98 or so......
