Will T-case from 96 fit 98?
Old Nov 25, 2013 | 11:17 PM
Thornloe Pride's Avatar
Thornloe Pride
Default Will T-case from 96 fit 98?
Tried searching for an answer but couldn't find it. Need to replace my transfer case. My parts truck is a 96 and I was wondering if it is interchangeable with a 98? Thanks
Old Nov 26, 2013 | 09:15 AM
97r/tram's Avatar
97r/tram
I don't think so because of the speedometer output and all that. Unless it will swap over.
Old Nov 26, 2013 | 09:36 AM
Actually, it should work. On the older truck, speedo is driven off of VSS in the output section of the t-case, on the newer truck, it uses the sensor in the rear diff. So, the 96 case into the 98 truck will work. The other direction would require a bit more creativity to get the speedo to work.
Also, keep in mind, the shift pattern on the 96 is different as well.
Old Nov 26, 2013 | 09:45 AM
Thornloe Pride
I'm trying to work out a deal for a 1998 ram 4x4 for parts but yeah, so far the 96 is my best bet. Will it work without modding anything? I would have to mod the speedometer output wouldn't I?
Old Nov 26, 2013 | 10:10 AM
97r/tram's Avatar
97r/tram
I'd swap the shifter over from the donor truck as well.
Old Nov 26, 2013 | 10:29 AM
Actually, the VSS in the older t-case simply won't be used. Nothing to plug in there, and the speedo will work just fine.
Old Nov 26, 2013 | 12:06 PM
Thornloe Pride
Okay thanks guys. Won't work with current shifter?
Old Nov 26, 2013 | 12:08 PM
97r/tram's Avatar
97r/tram
As hey you said, the shifting pattern is different. I mean you could always use your shifter, just put the **** from donor truck on so you're not driving in 4l by accident.
Old Nov 26, 2013 | 12:20 PM
Thornloe Pride
Ill take a look at it tonight. What happened was it snowed really heavy yesterday so I decided to take the girlfriend out and teach her how to use 4x4 in case she ever needed to borrow my truck if conditions are bad. Well after a while i took over and started playin. Went somewhere I shouldn't have. Snapped Dana 44 axle shaft at the U joint and transfer case is making some nasty noises. My buddy with a Rubicon had to winch me out. Now my girlfriend knows what not to do.
Old Nov 26, 2013 | 12:34 PM
Ooops.
Those are lessons worth learning as well.
Good Judgement is a result of experience. Experience is generally a result of bad judgement.
